question on dash light auto dim '97
Old 02-19-08, 02:01 PM
m0rs
m0rs's Avatar
Default question on dash light auto dim '97
Hey guys,
This is an observation I made. I dunno whats going on, but would like some comments.
On a cloudy day when I manually switch on my headlights.. and whenever the car passes under an overpass (or probably any darker areas) I notice that the dash lights and the clock/temperature lights go dim and after the car clears the overpass, the lights brighten up after a second.
What is going on? I'm thinking the headlights brighten up under darker areas and so interior lights go dimmer? or what.. I checked the manual and did not notice anything in particular.
This is on a 1997 LS..
Old 02-19-08, 02:21 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the light sensor on the top left part of the dash near the windscreen is adjusted to be too sensitive.
Old 02-19-08, 02:37 PM
m0rs
m0rs's Avatar
ohh okay.. Thanks!
Is is easy DIY to reset it to the default settings?
Old 02-19-08, 03:52 PM
PureDrifter
BahHumBug
u just turn it left or right (its in the owners manual which way is which) to adjust the sensitivity.
Old 02-19-08, 04:41 PM
Neofate
Neofate's Avatar
I guess First gen's didn't come with auto-dim. Or I just haven't noticed it.
I notice the lights come on and go off on their own in 'auto' mode.. which is handy. An auto-dim would be nice. Consider yourselves with added luxuries in 95+
Old 02-22-08, 11:43 PM
Spacepig
Spacepig's Avatar
My 98 LS does the same thing when going through an underpass/tunnel on a cloudy/ rainy day. I assumed that is was normal; the dash lighting is just adjusting to the change in ambient light. It was disconcerting when I first noticed it, as I thought maybe it was the beginning of a dash problem. But now I attribute it to thoughtful engineering; Toyota doesn't want me to have too much dash glare at night or in darker conditions.
Old 02-22-08, 11:53 PM
jcrome04
jcrome04's Avatar
My 97 does the same. I noticed it and got a little conflicted, but then went through a few more underpasses and noticed it's because of the sensor!
nothing to fret about!
Old 02-23-08, 12:31 PM
Och
Och's Avatar
The fist gen auto dims as well. The car has a sensor on the dashboard, near the windshield, and when it gets dark out, or if you pass under an underpass or any other dark area, it will dim the instrument cluster lights. However, it only does it when your headlights are on, if your headlights are off, it won't do anything. Also, the same sensor turns on the headlights when your headlight switch is set to auto. I believe there's a way to adjust it, but I have no idea how.
Old 07-04-11, 10:47 AM
ncbitman
ncbitman's Avatar
Does anyone know how to adjust the headlight sensor on the first gen?
Old 07-04-11, 10:30 PM
emarknot
emarknot's Avatar
only "auto dim" when you turn on your lights and you have the dash dial turned down.
yup, auto dim rules. 1st gen doesnt have it.
Old 07-05-11, 05:47 AM
deanshark
deanshark's Avatar
My 93 dash lights dim when I go through a tunnel with the headlights off. Maybe it has something to do with the dimmer used when the Headlights are on b/c I keep mine turned down almost all the way, 1 notch before off.
Lovecorond
RX - 1st Gen (1999-2003)
01-31-18 04:15 PM
islandsnow
05-22-08 04:25 AM
docdgt@com
09-27-07 07:08 PM
ZeekGS300
GS - 1st Gen (1993-1997)
12-10-05 09:34 PM
(f)-LEX-ible
12-09-02 04:08 PM
Quick Reply: question on dash light auto dim '97
