Front Brakes By Dealer-price?
Old 02-28-08, 06:50 AM
heyhowyado
heyhowyado's Avatar
Originally Posted by DIY LS400
^ no vibrations or squeals from the rotors? Technically you should clean the rotors with a scotch pad and some brake cleaner to get surface clean and fresh for the new pads. Pads leave crap on the rotor and for most cars, the brakes squeal and judder if the rotors aren't cleaned/turned.
no, no vibrations or squeals at all.....not sure if they cleaned the rotors or not.....is this something most mechanics do?
i CAN tell you they loved the fact that i was able to tell them how to repair the sensor....
Old 02-28-08, 01:06 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i personally ALWAYS have my rotors cut whenever i do a brake job. (its like $5 at napa anyways )
not at least scotchbriting the rotors to give some bite to the old rotor isnt the best idea as it prevents the new pads from bedding in properly and can lead to everything from squealing/noisy brakes (now or down the line) and even increased pad wear.
Old 02-28-08, 01:23 PM
heyhowyado
heyhowyado's Avatar
i'll have to remember that for next time PD.
Old 02-28-08, 02:21 PM
DIY LS400
DIY LS400's Avatar
Most mechanics recommend turning the rotors because it generates more money for them and also when the rotors get too thin and need replacing, that's even more money. lol.
From what I read, taking a rough, scrubbing pad, or something like that, and giving the rotor a good cleaning should be good enough. However, a freshly machined surface is always nice.
PureDrifter, I can't believe it's only $5~ over there at NAPA.
Old 02-28-08, 04:53 PM
PureDrifter
BahHumBug
its $5ish/each to turn the rotors (it takes them 1/2 an hour so i always do it around lunch time )
to clarify, you take them JUST the rotors (off the car) and they mill them for you
turning rotors is also a great way to save ur rotors when they get mildly warped.
Old 02-29-08, 10:36 AM
lenunn1923
lenunn1923's Avatar
Does the 2000 LS400 have the brake sensors too, if so what do they
cost to repair ??
Old 02-29-08, 11:23 AM
McSwine
McSwine's Avatar
to tag on to lenunn's post about the 2000, IF you change the pads before the sensors wear down, can they be reused? I'm about to do the pads on my 2000 tomorrow.
Old 02-29-08, 11:37 AM
PureDrifter
BahHumBug
yes, if the light doesnt come on on the dash then you can reuse the sensors.
and iirc brake sensors were on all LS' 89-00 but i know for a fact they were on all 95-00 cars.
Icy350
Suspension and Brakes
01-28-20 08:19 AM
ToyotaJon
RC F (2015-present)
17
08-05-18 05:46 AM
babyduke
ES - 5th Gen (2007-2012)
01-04-17 03:19 PM
11-02-16 11:23 AM
Todd
05-05-08 07:58 PM
Quick Reply: Front Brakes By Dealer-price?
