Post up Recent pixs of YOUR car (LS400s)
#3003
Finally installed my 99-00 wood steering wheel. I was slightly worried that it won't fit when I ordered it, but it turned out to be identical, except with matching woodgrain.
![](http://farm7.static.flickr.com/6001/5944934829_4db7ba1b1c_b.jpg)
It's not perfect, but I got it for $150 shipped, so I can't complain:
![](http://farm7.static.flickr.com/6017/5945488392_0337c67afc_b.jpg)
Here's some random macro shots too:
![](http://farm7.static.flickr.com/6149/5945489788_e354015a74_b.jpg)
![](http://farm7.static.flickr.com/6003/5944930355_b3ee3e4737_b.jpg)
![](http://farm7.static.flickr.com/6029/5927459487_f6642d507e_b.jpg)
![](http://farm7.static.flickr.com/6007/5927451809_21d936f72a_b.jpg)
![](http://farm7.static.flickr.com/6126/5927449515_f2e35a3a74_b.jpg)
![](http://farm7.static.flickr.com/6123/5928006122_86ec54cd0c_b.jpg)
![](http://farm7.static.flickr.com/6015/5927445217_afbd43a44a_b.jpg)
#3005
It was pretty easy to install. Just disconnect battery, remove the two torx screw on the side (you need a torx bit for this), remove the big nut in the center, unplug everything, take a mallet and start tapping the steering wheel all around until it pops out (took me a while, had to use some WD40 too). Then replace whatever components is missing on the new steering wheel and put everything back together (just make sure you don't mess up the alignment, be sure to put the new one back in the same position as the old one....so it's worth noting/marking what position the old steering wheel was in before you remove it).
#3010
Progress! Remember when your pulling your fenders to take your time. I pulled mine in like 20 minutes because idgaf and need body work anyways.
Also what size tire do you plan on running? I'm running a 215/35 Nankang NS2 on the 9 and a Fullrun 215/35 on the 10. So essentially 205/35 and 215/35.
#3013
not positive, they are in my shed until the adapters get in. i think im a 245/35 rear with 225/35 front. they both have a very slight stretch... so i got my work cut out for me haha
