Post up Recent pixs of YOUR car (LS400s)
#3468
Here's my 1990 please don't mind the primered side panels went with newer side skirts but didn't get the panels i time I painted it myself enjoy!
#3471
Right now the car is already up on craigslist to see what I can get. I need monies
#3473
Egh97t-
to be honest I got some nuespeed springs from the junk yard because my air susp were blown threw them on wasn't low enough so went at it with a grinder and it also rides surprisingly good...
#3477
the stock bulb isn't orange, it's clear which emits a nasty yellow. it's the orange cylinder/capsule that goes over that clear bulb that makes it orange. don't know why lexus didn't originally go with the orange bulbs instead of the clear.. it would've still had that orange look in the housing. oh well.
i didn't want to spend the extra money to buy another set when i could just work on my current set so i cracked the orange capsule. it was tedious and took up a good 30 minutes for one side since i didn't have the right tools.
if you want, here are the clear ones.
http://www.ebay.com/itm/New-Corner-L...item35b3b02d5f
http://www.ebay.com/itm/New-Corner-L...item3a6b7c889e
all you gotta do to get rid of the orange is to change out the bulb to either a chrome stealth bulb (same as stock but dipped in chrome and has less light output than stock cause of it) or pop in an LED. you can also use your stock bulbs which should be clear but it will emit yellow when you use the turn signal. that's not bad at all since our turn signals dont stay lit like on many other cars.
do keep in mind that using LEDs without resistors will cause hyperblink on the turn signals. that's why i resorted to sticking to my stock clear bulb.
