Post up Recent pixs of YOUR car (LS400s)
#4367
I just noticed in your signature that you have an SS kit. I want it lol. I need NRCA in the front really badly. Camberwise im at like -3 in the front (NOT ENOUGH AT ALL) and about -6 in the rear (ALSO NOT ENOUGH)
Im running 225/40/18 in the rear and 215/40/18 in the front. They are all crappy nankang NSII because they stretch well and I drive like a grandma so I never worry about taking corners haha.
#4371
#4373
Yea, I have the SS kit (front and rear). Maybe it's me, but i was able to get additonal negative camber after installing the kit. I was maxed out at -3 front but currently have about -3.8 front and -4.5 rear. As for the NSII, i run those in the front, downsides: low treadwear and they're a bit noisy, but they do have a nice stretch. lol...I drive the same way; but it's sorta necessary for being low.
When SS Kits/RCAs are installed you're supposed to raise the coilover mount the same thickness as the RCA to compensate for this, so you end up at the same height as pre-RCA.
#4376
if you use the SS kit to lower the car further instead of correcting the suspension geometry you will obviously gain negative camber at the expense of further hurting the steering/bump steer/tramline effect as you're mucking up your roll center.
