Horn replacement question.
Old 03-09-08, 07:28 PM
shonn
shonn's Avatar
Default Horn replacement question.
So I have no horns. yep, none. all I see is a wire on the left and a wire on the right, both appear to be green. There is a another one that has a green and a white wire in a black sleeve. What wires do I need to hook up these new horns? Any info and pics would help. thanks.
-shonn
Old 03-09-08, 07:43 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
grn/wht is +12v and the other wire (grn/blk/whatever) is the ground.
Old 03-09-08, 08:11 PM
Kansas
Kansas's Avatar
Are there connectors at the end of your horn wires? I don't know if all Toyota vehicles had the same horn connectors but I have verified that our 00 LS, 98 Camry, and the 90 LS I use to have all had horns with the same connector type.
Old 03-09-08, 08:18 PM
shonn
shonn's Avatar
ah so if i connect the grn/wht and use the ground wires that came with the horns and ground em. they should work correct?
And there are connectors but they're all messed up so can't use em.
Old 03-09-08, 08:23 PM
PK_Celsior
PK_Celsior's Avatar
hehe time you make your own connectors. try to solder them together than put some electrical tape on that bad boy. but i rarely use my horn i just yell .
Old 03-09-08, 08:26 PM
1995LS400
1995LS400's Avatar
Would it be silly to install some Ferrari horns on an LS? I was thinking of doing this but I wanted some input from you guys first.
Old 03-09-08, 08:27 PM
PK_Celsior
PK_Celsior's Avatar
i seen people put on train horns. so that wont be silly at all until i hear a train horn from it. just make sure it sounds beefy . make yourself unique hehe
Old 03-09-08, 08:42 PM
avalon42
avalon42's Avatar
I gotta have more cowbell!
Old 03-09-08, 08:45 PM
PureDrifter
BahHumBug
yea, that should work fine.
im eventually gunna get some hella horns for the car, loud AND legal
Old 03-11-08, 12:00 AM
shonn
shonn's Avatar
Ok I'm having a hard time with this one. Can someone just explain to me how to hook these up? Thanks.
LexBrett
05-19-15 12:02 PM
bryan767
Performance & Maintenance
04-19-11 10:00 AM
m32
03-13-08 03:28 AM
blackbelt
10-24-06 03:44 PM
Kizoku
05-14-02 05:27 PM
Quick Reply: Horn replacement question.
