Will This Offset Work On A 95 LS?
Old 03-13-08 | 11:14 AM
supdawg2u's Avatar
supdawg2u
Default Will This Offset Work On A 95 LS?
I am looking at a pair of 17x9 wheels with a 24mm offset in the front and 17x10 wheels with a 20mm offset. Will these fit the Lex?
Old 03-13-08 | 11:19 AM
NJ240sxMan's Avatar
NJ240sxMan
CL Folding 25,000
I think you'll have to roll your fenders but that's about it. Iirc 2LS's have deeper fender wells than 1LS's.
Old 03-13-08 | 11:51 AM
supdawg2u's Avatar
supdawg2u
That's what I was thinking I would probably need to do...thanks!!
Old 03-13-08 | 01:09 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
What disk setup are the fronts? You would need a high disk setup and/or possibly a small spacer to clear the brake calipers.
Old 03-13-08 | 01:55 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
and why not 18s if i may ask?
the rear will require a roll.
the fronts will require a roll and depending on the chosen tire size/ride height a mild pull and/or increased negative camber as well.
Old 03-13-08 | 02:43 PM
Neofate's Avatar
Neofate
CL Folding 10,000
I thought he was putting on 17's ?
Old 03-13-08 | 02:50 PM
supdawg2u's Avatar
supdawg2u
Yeah looking at 17x9 and 17x10s...not 18s
Old 03-13-08 | 03:05 PM
PureDrifter
BahHumBug
CL Folding 100000
i know, i asked why you chose 17 instead of 18s
the fitment is the same regardless
Old 03-13-08 | 04:02 PM
Neofate's Avatar
Neofate
CL Folding 10,000
the fitment works regardless
and why 18s if i may ask?
I think the 'not' was forgotten. -- Irrelevant, you say the fit will work irregardless,..
Old 03-13-08 | 04:23 PM
PureDrifter
BahHumBug
CL Folding 100000
fixed, and i meant that he will need to do the same, things for either with the given offsets.
Old 03-13-08 | 04:30 PM
supdawg2u's Avatar
supdawg2u
little more tire (sidewall) and just something different...typically everyone goes with the 18in +
If I don't like the way it looks...I've got a set of 18's in mind already...
Old 03-13-08 | 07:07 PM
Neofate's Avatar
Neofate
CL Folding 10,000
Just yanking your chain PD. -- I knew what you meant,.. So serious
Old 03-13-08 | 08:24 PM
stuching's Avatar
stuching
http://www.1010tires.com/WheelOffsetCalculator.asp
SRTISF
IS - 1st Gen (2001-2005)
12
06-12-23 11:35 PM
vbspunger
01-30-09 04:20 PM
JBrewster
09-19-07 11:40 PM
IS_NIICE
05-24-07 07:57 PM
kilo6_one
11-28-06 12:35 PM
