How to pull codes on a 96
Old 03-15-08, 02:32 PM
JBrewster
JBrewster's Avatar
Default How to pull codes on a 96
Edit: Code P0110 IAT Circuit Malfunction. Where is the IAT located on this car?
without a codereader? Is that possible? I know some cars have a trick sequence to get the light to flash the code.
Also is there a list of codes somewhere. I searched but maybe I missed it.
It came on after I gave my motor a little spray with atf when I was flushing my power steering. ****ing hose slipped out of the bottle. Engine and garage are covered in oil now. Looks like blood splatter on the wall lmao.
Old 03-15-08, 03:11 PM
sonyman
sonyman's Avatar
Hook up a codereader. It's OBD-II.
Old 03-15-08, 03:16 PM
JBrewster
JBrewster's Avatar
Yeah but can you do it without a codereader?
Old 03-15-08, 03:24 PM
sonyman
sonyman's Avatar
Originally Posted by Lexus Repair Manual
When troubleshooting OBD II vehicles, the only difference from
the usual troubleshooting procedure is that you connect to the
vehicle the OBD II scan tool complying with SAE J1978 or LEXUS
hand–held tester, and read off various data output from the
vehicle’s ECM.
No. You must use an OBD II scan tool.
Old 03-15-08, 05:55 PM
JBrewster
JBrewster's Avatar
OK I decided to stop being cheap and bought a scanner. Got a code P0110 IAT Circuit Malfunction...
Any ideas? Where is the IAT located on this car?
Edit: I went ahead and cleared the code. We'll see if it comes back. I had the MAF disconnected ealier so it may have had something to do with that.
Old 03-15-08, 07:03 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
on the MAF.
and starting in 95 the LS400 went OBDII, the flashing light deal is only with OBDI cars
Old 03-15-08, 10:26 PM
drewkaree
drewkaree's Avatar
Some auto parts places also let you pull codes with their reader. I've done that at AutoZone before. All they're really trying to do is to get you to buy parts from them, so it's kinda like an "advertisement". If'n you plan on owning a car newer than '96 though, might as well buy one if you prefer to work on your own car. I've got one on the way from Amazon so I don't have to waste my time driving to AutoZone again and again.
dadewi
GS - 1st Gen (1993-1997)
12
10-22-18 12:45 PM
jasawh
02-24-18 06:29 AM
CallmeQ
09-26-09 12:19 PM
StiCk3
Performance & Maintenance
04-26-08 05:40 AM
forcefed86
01-05-08 03:41 PM
Quick Reply: How to pull codes on a 96
