should i change the springs or just the shocks/struts?
At that mileage I'd actually suggest replacing the springs and struts. After 150k miles the struts and springs in the car are definitely tired. Go with KYB shocks for the ride closest to OEM.
Given that -- What would spings and struts all the way around run on a 94 LS 400? Cheapest, but still good. From what I read, the parts that give factory type ride quality but not much performance increase are much cheaper than the parts that give substanital handling increase but you lose ride quality.
I'm more interested in ride quality.
I wouldn't mind lowering the car a half inch or so, (only slightly) if I'm going to put aftermarket springs on. Just curious where you would point me.
If some spings and shocks, and struts hehe.. could be had for 5-600$ then take the car into a decent suspension shop for installation, of say 400$.. A grand for such wouldn't be bad imo.
It has 229k, so it is tired, but nothing that can't wait.. But I bet it would be a drastic difference in ride quality.
Yeah I realize that -- lower center of gravity = better handling. But also negates some of the ride quality.
Which is why I mention half an inch or so. This is on the low side of lowering, and shouldn't make a drastic difference in ride quality or performance. Slightly worsening one, and slightly increasing the other.
However, with my 230k suspension, I almost think a half inch drop with NEW components would make the ride quality better than it currently is. Simply because the suspension with 14yrs and 230k miles is operating at 25% capacity imo. New suspension , even rated more harsh than 'NEW' stock suspension.. will be less harsh than the OLD worn out stock suspension on there now. Make sense?
So I would be getting an improvement both ways,.. If my thinking is correct.
oh, and install shouldnt be more than 300, and if you're wiling to undo a few bolts and take out the rear seat, it should be even less than that.
I just bought a full set of Bilsteins along with H/R springs.
This wont ride like a Mustang will it?? I'm looking for a touring sedan ride.
AND for Olddog..if you ride has alot of miles on it then i would consider changing both springs and struts...but thats just my opinion.
Golden95SC
Suspension and Brakes
10-25-12 12:46 AM
jcat_350
09-28-08 05:08 PM
