Will these speakers work?
http://www.crutchfield.com/App/Produ...TR525CX&tp=105
FOr the front doors?? WIll it sound better. I will use them with a stock amp and stock radio. I dont want to change that.
And Ia lready have two 10' subs in the back, there is pleanty of bass, but not clean punchy bass at low volume. SO I am trying to clean the sound up a little since it looks like I'll be keeping this car for another 5- month or so.
I am also getting JL w3v2 10inch woofers later.
But are these speakers for the front door even worth changing?? Is the size correct?
And can I set them in the rear as well?? if not why not?>
Many thanks!
Many thanks!
what year LS4? there is a tutorial on Lexls.com on installing larger speakers in the factory 4" opening. http://www.lexls.com/tutorials/audio/fspeaker.html
98. 4 inch??? jesus. Thanks
Now I am wondring if the 4 inch in specially designed facotry box works better than 5.25 just hacked in. You need the proper volume for it, no?
i've crammed some 5.25's in mine, but it takes some work and time and it's really not worth it imo. just get some good 4's and bolt them in and be done with it.
fwiw, you'll never have clean tight sounding bass from ANY sub int he back of an LS because the fuel tank is between teh trunk and cabin, which is seperated further by a solid sheet of metal behind the rear seatback.
the only wya to do it is to build a custom box, porting the output directly through the factory sub hole in teh rear shelf.
i run 2 12" pioneer subs with a 1200 w rms diamond audio amp and it sounds ok at high volumes, but still not as clean as it could. i have a 10" audiopipe off 600w of cerwin vega amp in my jeep and it sounds 9/10 as loud and cleaner and tighter at the same time.
With modern audio equipment the number one loss in sound quality comes not from the headunit or amplifier, but from the speakers. Conversely, cheaping out with $30 JL's would be a mistake. Also keep in mind that the front speakers are components from the factory, and the ones you linked are not.
It's not all about size. One of the biggest reasons for having a larger speaker with a larger mass is for good low-frequency response. All LS400's have always come with a subwoofer, and therefore 4" sufficed.
Thanks for answers. I will skip this project. Looks like margina gains for too much work and I am out of that door panel removing age to dump speakers into it.
gazi001
RX - 1st Gen (1999-2003)
14
03-19-11 01:50 PM
CleanSC
08-25-04 09:00 AM
