Red or Pink coolant?
Old 08-20-09, 03:19 PM
97CE LS400
97CE LS400's Avatar
Originally Posted by trukn1
^^Should be pretty much be the same.
Thanks for the clarafication trunk1
Old 08-20-09, 03:33 PM
chriswins
chriswins's Avatar
I use red but it think they're both pretty much the same thing
Old 08-20-09, 08:16 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
they arent...
Old 08-21-09, 11:05 AM
3UZFTE
3UZFTE's Avatar
Red is Long Life coolant, designed to go like 30k. Super Long Life, or the pink stuff is supposed to go 60k or longer. SLL supersedes LL, so if you use it, it won't differ in performance. My GS430 came with red, and since I worked at Toyota, I drained and flushed and now I run Pink, it's been at least 30k miles since. I will add that Pink is more expensive than Red, and they also recommend to flush it every 30k anyways, but I don't do it.
Old 08-21-09, 11:18 AM
damon
damon's Avatar
I am in the homestretch of this procedure. Very tough to get 2.8 US Gallons back in a LS!!
I was on fairly level ground & noticed that very little coolant came out of the Drivers side engine block drain. No idea why??
Old 08-21-09, 02:30 PM
PureDrifter
BahHumBug
did you open the top freeze plug AND the overflow cap before draining?
Old 08-22-09, 12:59 AM
damon
damon's Avatar
I had 5 open orifices!! If I missed one now is the time to know!!
Whatever is in there now is either Toyota Red, Distilled water or Tap Water.
Green no more!!!
Old 08-24-09, 07:30 AM
3UZFTE
3UZFTE's Avatar
Not that there is anything wrong with green anti-freeze, heck it's been around longer than most of us. But it just doesn't last as long as the long life stuff, which it needs to be maintained about once every year or so.
Old 08-24-09, 11:24 AM
nthach
nthach's Avatar
Pink is a hybrid phosphate/organic acid coolant - but unlike Dex-Cool which uses 2-EHA and either sodium or potassium neodecanate as the organic acid, it uses sebacic acid as the organic acid.
Red also contains phosphate but the ingredient listing also states a tiny amount of sebacate.
Both contain no amines, nitrates, and borates.
joeyfett
02-12-14 06:46 AM
HarrierRX300
Maintenance
05-09-10 10:29 PM
wvuguy
RX - 1st Gen (1999-2003)
14
04-17-10 09:05 PM
arodriguez
Maintenance
01-09-09 03:52 PM
rtk7
01-12-08 02:20 AM
Quick Reply: Red or Pink coolant?
