Parking brake light comes on under braking
Old 04-05-08, 05:40 PM
Ls4hundred
Ls4hundred's Avatar
Default Parking brake light comes on under braking
Sometimes under heavy braking , or braking downhill my parking brake light comes on. Is this just a loose cable?
Old 04-05-08, 05:50 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
no, ur low on fluid in the reservoir, double check.
Old 04-05-08, 06:39 PM
sonyman
sonyman's Avatar
Seconded. Your fluid level is low.
Old 02-21-09, 06:21 PM
shern
shern's Avatar
95 LS here with the exact same issue. What happens if your fluid is not low and the light comes on under hard braking? Fluid looks a bit dark and may be dirty.
Old 02-21-09, 09:06 PM
PureDrifter
BahHumBug
flush the fluid and in the process check the sensor, might be jammed/stuck/dead.
jbl-1985
05-05-17 04:05 PM
sveinongen
07-18-10 03:20 AM
philES300
Maintenance
10-16-06 09:21 PM
bizzy928
RX - 1st Gen (1999-2003)
12-18-05 07:52 AM
AaronE
Maintenance
05-12-04 09:50 AM
Quick Reply: Parking brake light comes on under braking
