View Poll Results: Still drive with spare tire?
I am driving without the spare tire.
14.63%
I am driving with the spare tire.
35
85.37%
Voters: 41. You may not vote on this poll
Old 04-14-08, 01:39 PM
haulin79
haulin79's Avatar
Sonyman,
I believe the mpg formula was derived empirically.
No scientist, engineer, or physisict would believe that any empirically derived formula can describe what happens in real life.
Old 04-15-08, 02:05 PM
omarg
omarg's Avatar
a lighter foot and driving without crap in the trunk will do much more in real word savings. I would much rather have my full size spare, than an undetectable performance, mileage boost.
Old 04-15-08, 04:34 PM
RA40
Super Moderator
RA40's Avatar
The stock wheel I use as my spare weighs in at 48#'s. My 18's with the new rubber comes in at 50#'s. If you are doing timed runs, yeah, the 50#'s may make a difference but overall to get caught without a spare is not worth it.
Old 04-16-08, 12:56 PM
Rocan
Rocan's Avatar
Seriously, if you need the performance so often that your better off removing your spare, then you should keep it in there for when that spike strip blows out one of your tires...
Old 05-14-08, 11:25 AM
TJW98LS
TJW98LS's Avatar
Originally Posted by sonyman
Where'd you get your weight numbers from?
The 1998-2000 LS400 weighs 1764.5 kg. With your estimage of a 20.4 kg spare, the times are as follows:
0-60 time of 6.76 seconds with spare
0-60 time of 6.68 seconds without the spare.
I still don't buy the 0.477 mpg improvement though. There are too many variables to take into account for some simple formula.
those 0-60 times are too high! I get better numbers WITH my spare
Old 05-14-08, 02:37 PM
gdave
gdave's Avatar
man, im always keeping my spare even though i have AAA its good to have cause they always take atleast 30 min and i can change in well under that........o....yea my HUGE sub box with 2 subs an amp and made from 3/4 MDF its probly at least 60 pounds.going up steep inclines is fun all in the name of LOUD MUSIC
Old 05-15-08, 06:05 AM
Thermactor
Thermactor's Avatar
Removing the spare tire has been the best decision I've ever made. It's dramatically increased my size and stamina. My bank account is flush with cash and now I can fit four Baltic hookers in my trunk instead of three. All because of removing the spare tire.
Old 05-15-08, 07:12 AM
heyhowyado
heyhowyado's Avatar
LMAO..........
Old 05-15-08, 09:26 AM
demonboy
demonboy's Avatar
I don't know why you are so concerned about mpg if you drive a lexus. If your so desperate to get better mpg that you will risk driving without your spare tire over saving pennies for gas, then just get a car with better mpg.
Old 05-16-08, 09:02 PM
AHJ
AHJ's Avatar
Default Could not get the wheel off
I tried to take the wheel off and did not succeed while using the standard socket wrench supplied with the car.
The nuts or on so tight I had to bounce on the wrench. This worked until the security keyed lug and the wrench kept slipping off when I stood on it and bounced.
So if you have security keyed lugs and just the standard wrench, give it a go before feeling comfortable about it.
I think a cross bar wrench would be handy here.
Old 05-16-08, 11:05 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
its not the wrench design, its a problem witht he idiot who overtorqued the lugs when they were last removed...
Old 05-16-08, 11:37 PM
1995LS400
1995LS400's Avatar
Exactly! The idiot probably used an impact wrench to tighten them.
Old 05-18-08, 11:17 AM
haulin79
haulin79's Avatar
It's interesting to see that the LS guys get rid of their spares at a 1:8.5 ratio (i.e. 4 people drive without spares and 34 keep their spares).
While the SC guys get rid of their spare tires at a 1:1.9 ratio (i.e. 36 people drive without spares and 67 keep their spares).
I guess it is obvious that the SC guys care more about performance and the LS guys care more about safety and convenience.
Old 05-18-08, 12:41 PM
PureDrifter
BahHumBug
theres also the fact that the SC can be easily made into a performance car, and therefore will be more apt to getting stripped out for weight reduction, than the LS.
Old 05-19-08, 12:09 AM
chubby
chubby's Avatar
i can't believe someone would bring up the idea of removing or leaving a spare. seriously, in real world conditions it wouldn't matter whether your spare tire is in the back because there are other bigger **** that you would have to worry about. i think this thread is a joke. and about SC crew not having spares in the trunk.. a lot of them do that because most of them hit the track with it. without a spare in an ls, you're looking at .477 mpg improvement which is literally a drive around the block
cheezz
02-14-19 05:57 PM
fas2000
12-28-16 07:30 PM
daryll40
06-19-11 02:18 AM
haulin79
SC- 1st Gen (1992-2000)
74
05-29-08 06:42 PM
i3urton
11-06-07 10:30 AM
Quick Reply: Still drive with spare tire?
