LS400 Projectors
Old 04-24-08, 05:39 AM
salsaboi
salsaboi's Avatar
Lightbulb LS400 Projectors
What projectors would fit best in an LS400 98-2000 headlight housing? I personally want the Q45 projectors coz they look so cool. How would they fit? I have a pair of ES300 headlights that are just lying around and I'm thinking of trying them out. What do you guys recommend?
Old 04-24-08, 05:41 AM
salsaboi
salsaboi's Avatar
Btw .. the ES headlight is a '96 one
Old 04-24-08, 09:56 AM
PK_Celsior
PK_Celsior's Avatar
i saw a LS430 with Q45 retrofits. it look hella gangsta.
check it out
Old 04-24-08, 10:57 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
ehh, hidplanet and even the CL lighting forum agree that the Q45, while looking hot, dont have nearly as good light output as the S2k, LS430, or even the TL/TSX projectors.
Old 04-24-08, 11:40 AM
salsaboi
salsaboi's Avatar
check it out
B R B , W-A-N-K!!
Old 04-24-08, 04:48 PM
skperformance
skperformance's Avatar
Agreed . the Q gatlin gun projector is an esthetic not a purposeful design. Its output is like a halogen bulb even thought it is a HID.
The smallest and easiest for space is the TSX with 96 and newer have a fresnel lens which gives you a less sharp cutoff but gives you more visible area to see.
Old 04-25-08, 02:21 AM
salsaboi
salsaboi's Avatar
Like a halogen? Are you serious!?
It can't be as bad as the UCF20 I now can it?
Old 04-25-08, 03:37 AM
PureDrifter
BahHumBug
it will be comparable to the OEM HID output, not sharper by much if at all.
Old 04-25-08, 07:40 PM
skperformance
The actual light output on the road of the q45 headlight is just as crappy as a halogen bulb on a normal car. I do not see ucf20's in Canada that have halogens as all have HID's here but just a normal car with halogens is what its output is like. It really really sucks.
Old 04-26-08, 02:30 AM
salsaboi
salsaboi's Avatar
Anyone tried out the P7 projectors from Lotarev Automotive? They look almost like the Q45's .. Any info on the light output? They got a pic on .. looks pretty okay to me.
http://cgi.ebay.com/ebaymotors/UNIVE...QQcmdZViewItem
Old 04-26-08, 07:58 AM
greenvy2k
greenvy2k's Avatar
in my opinoin the 2004-2006 ls 430 projectors with the shroud fit perfectly. it is almost like lexus designed them to work with the 98-00. i love the light output and the width.
Old 04-26-08, 08:33 AM
Jasbmo
Jasbmo's Avatar
Wow that looks funky, esp. with the housing in black, do you have any pics of the light output at night?
Old 04-28-08, 03:33 AM
TropikalLS
TropikalLS's Avatar
I plan on doing a HID retro fit myself, I have a set of S2000 and TSX projectors with ballast I picked up off ebay sometime ago. I need to get a spare set of headlights to hack up in the meantime.
I like the LS430 projectors in the housing and I will end up painting the housing black also to cut down on glare.
Old 04-28-08, 10:46 AM
PureDrifter
BahHumBug
painting the housing black wont "cut down on glare" once u retro projectrors.....
unless you do it poorly and have lots of light leaking.....
the only reason i havent done a projector retro is coz i dont see the point since i already have factory HID, and its hard to find someone who is comfortable working with the AutoLevel
Old 04-28-08, 04:48 PM
greenvy2k
greenvy2k's Avatar
i like these projectors for the colors that it produces while looking at it from afar. i really want to get some BMW lenses to get even more color and sharper cut off.
Quick Reply: LS400 Projectors
