Transmission fluid, draining & flushing (The Mother thread)
#152
you guys are nuts! don't try so hard to spend money!
just read your owner's manual- it states the type of fluid it needs. simple ATF. and do NOT power flush it, which can dislodge particles into the solenoids, etc... just a fluid exchange, which any competent shop (including a decent valvoline shop) can do for $80. there is no truth or logic in thinking an abused xmission will be hurt with new fluid-- except for the power flushing above.
done mine twice this way- completely fine. it's the fluid the car calls for!
jc
jc
the manual states Toyota T-II (now T-IV) fluid in the trans, and regular ATF (dexron/mercon) in the PS.
#153
Not to spam in this thread or anything, but I can get the genuine Toyota T-IV ATF for $7 per quart. I don't know if that's a good deal or not, but just putting it out there.
#154
#157
ok ok guys heres the deal for all of you that want to know. went to lexus today and they quoted me 150.00 for a 2qt drain and refill and 380 for a full flush and refill. the service guy said to go to toyota so i did and now im getting a full flush and refill on T fluid for 220. so thats it for you whom need to know.
#158
i agree with puredrifter, you can only use T-IV ATF. when i first went to autozone, they told me that toyotas use only that fluid. they recommended me not to buy any of the stuff they sell there.
its only a few bucks more and plus, you don't have to change it for a while, why compromise your tranny to save a few bucks???
and the manual only tells you to use T-IV fluid as well!
#159
#161
By the way, it's called 3309 because it meets the JWS 3309 specification. Any ATF that meets the 3309 spec should work with all Aisen Warner transmissions that require either T-IV fluid or fluid meeting the JWS 3309 spec.
#162
http://www.lexls.com/tutorials/trans...ransflush.html
total cap. for a 1LS is ~8.3L.
basically u drain+fill then run it for a while to circulate the fluid then repeat.
keep doing that until fluid comes out red. normally u need around 10-12 and maybe even 14L of fluid.
Thanks!
#164
I also think another reason why is because Ford and GM are buying Aisin trannies for a few models, and Volvo/VW/Audi are also using Aisin trannies.
