Transmission fluid, draining & flushing (The Mother thread)
Old 09-28-09 | 02:58 PM
  #256
qewani1's Avatar
qewani1
Default transmission fluid amount?
how much fluid is required for LS400 2000 model' s transmission.
Old 09-28-09 | 08:45 PM
  #257
CO-LS400's Avatar
CO-LS400
2.5 quarts for a simple drain and fill.
Make sure you buy Type IV tranny fluid. You can buy it at the Toyota dealer.
Old 09-29-09 | 06:56 AM
  #258
qewani1's Avatar
qewani1
Thanks...................
Old 09-29-09 | 04:28 PM
  #259
e7liu's Avatar
e7liu
the total transmission fluid is 8.9 quarts. So if you want to have total fluid change that is the total quarts needed only use TlV toyota fluid only.
Old 10-31-09 | 10:54 AM
  #260
thefed's Avatar
thefed
Default Got a tranny 'flush' and Mercon V was put in....
My neighbor is a mechanic at a nissan/ford dealer. He took my lexus to work for an oil change and i asked that he do a tranny drain/refilll...not flush. the rcpt shows he used 5 quarts of mercon V ATF ???
I know the lexus calls for Toyota type IV. What should i do? Drain/refill a few times with the right stuff? Or add a friction modifier like lubguard?
Old 10-31-09 | 11:40 AM
  #261
Bradster's Avatar
Bradster
Some mechanic Drain..flush and refill with type lV
Old 10-31-09 | 01:00 PM
  #262
Och's Avatar
Och
You can't just drain and refill, that only drains like 1/4 of the total fluid. Your best bet is to do a full flush. Theres a tutorial at lexls.com
Old 10-31-09 | 02:41 PM
  #263
python's Avatar
python
he almost got it right...there is a V in both types of fluid! lol
Old 10-31-09 | 02:55 PM
  #264
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100000
you'll need a full flush with ~10-12qts of Toyota T-IV now. mercon and dexron spec. fluid will burn the tranny up.
Old 11-01-09 | 03:19 AM
  #265
Partycrash's Avatar
Partycrash
You can use Castrol Import multi vehicle also, it's spec'd to T-IV also and it's at Autozone.
Old 11-01-09 | 07:56 AM
  #266
python's Avatar
python
u can also use valvoline max life, u can also put in lube gard friction modifier without flushing,just put it in right now...
http://www.transmissioncenter.net/lubegard.htm
Old 11-01-09 | 08:26 AM
  #267
tromly's Avatar
tromly
+1, what kind of mechanic thinks that all trans fluids are the same, does he also have the same reasoning with oil ?? Hope he never works at a Lexus dealership.
Old 11-01-09 | 10:45 AM
  #268
TexFinn's Avatar
TexFinn
Hopefully you didn't have to pay anything for this "service".
Old 11-01-09 | 01:13 PM
  #269
Och's Avatar
Och
Most mechanics are like this, this is why you need to do your research first, and bring your own parts/fluids to the repair shops.
If you want your car repaired properly, but don't have the means to repair it yourself, you need to at least identify the problem and learn how to repair it, and then bring it to a repair shop, and watch them work to make sure they do it properly. And like I mentioned before, always bring your own parts and fluids.
Old 11-01-09 | 02:27 PM
  #270
Lexozz's Avatar
Lexozz
Dude why you give him your LS in the first place if he works @ a Nissan/Ford dealership? Drain that crap out, you may have to do another flush, but not really recommended. Take to a certified Lexus mechanic or stealership.
