Transmission fluid, draining & flushing (The Mother thread)
#481
#484
Can someone confirm the partnumber for filter and gasket for the 98 LS400?
35330-50010 or 3533030070. Also is that okay to go with RockAuto BA or or any other recommendations please. I see the OE uses as sealer if so what is the part number for pan sealer incase I am going to get the OE?
Thanks
@YODAONE @RA40
Thanks
@YODAONE @RA40
#485
Part# 35330-30070: Looks to be the correct one for the '98:
https://www.lexussouthatlantaparts.c...533030070.html
35330-50010 would be for the 95-97.
Sherl (01-10-20)
#486
I have no idea if this is generally useful or not. When I do a normal quick drain and fill on my 1998 LS400 transmission (when also changing motoroil) I get less then 2 quarts out from the transmission pan.
Have done that 5+ times. When I did it the last time the car had been sitting idle for ca 3 months and was also elevated in front for a week or so for Timing belt work etc.
Then to my astonishment out came 3.7 quarts from the transmission ! . Have no idea why that much came out.
I am positive that it was not overfilled.
#487
Destrier
01-24-13 05:02 PM
elite7
09-21-11 09:31 PM
02, 0888602305, 1990, 1991, 1992, 1995, 1997, 1999, 2000, 2004, 2005, 2008, 350, 400, 4000, 470, 91, 92, 93, 95, 96, 98, 99, a, a340e, add, additive, amount, amsoil, atf, auto, black, brown, call, car, castrol, change, changing, cheap, check, checking, circulating, city, club, coil, cost, date, dexron, dextron, difference, direct, diy, drain, drainfill, dys, es250, es300, es330, es350, fill, filter, fiuid, fj80, fluid, fluids, flush, frequency, fulid, gearbox, good, gs300, gs400, gs430, gx, gx470, hose, hot, ii, iii, is300, is350, iv, landcruiser, level, lexus, life, location, ls, ls400, ls460, lubegard, lx470, max, maxlife, mechanic, mercon, needed, not, oil, or, pan, plug, powersteering, price, problems, put, quarts, refill, replace, replacement, rough, rx300, sc300, sc400, shift, shifting, slipping, slips, smoother, substitute, suggested, syenthetic, synthetic, t4, teal, tii, tiv, toyota, tranmission, tranny, trans, transmission, transmisson, tundra, turns, type, upshift, valvoline, ws, xmission, york
