Getting OEM struts installed on '91 LS400 - What else?
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Right now the struts are absolutely shot. I feel every bump in the road.
I can get OEM struts for $496 including tax (front and back) from a friend of a friend who works at Toyota.
I can get (4) inner and outer tie-rod ends for $66 shipped from ebay.
I can also get (2) front sway bar links for $42 shipped from ebay.
I know a gentleman who will install the struts for $200, not sure how much extra to charge him to install tie-rod ends and sway bar links?
The dilemma is this. Money is an issue, I know strut mounts are recommended but some say I can use current mounts if they are in good shape. The problem with that is, the strut mounts I can find on ebay won't be on hand if the mechanic has everything already off. I'm worried I might end up needing the mounts if the current ones are bad.
Also, what else should I change? I've heard insulator/isolators/bumpers/boots are recommended but they are very expensive through Lexus. Is it ok to just get struts/tie-rod ends/sway bar links installed and still get that Lexus soft feel back?
I welcome all opinions from you Lexus junkies.
I used the old strut mounts since they were not worn. Not sure why you would have to buy new ones unless the rubber is completely worn through. Do you know if your inner / outer tie rods / sway bar end links are bad? That is, did you jack the car up and grab them to see if there was excessive play?
$200 seems fait to change all struts as I helped my brother-in-law Saturday do his ES model - more difficult than my LS.
I for one want the soft, "pillowy" ride. That's what stood out for me the most when I first test-drove this car over a year ago. It felt like heaven just driving on the freeway. I miss that. Sorry to get all fluffy.
thanks for the advice though. How do the GR2's feel on the road. Is it a soft ride? Is it a different driving experience?
As far as the $200 installation fee being expensive, it was roughly $400 less than what a local shop wanted to charge for install.
I figure $500 for struts, $100 for tie-rod ends/sway bar links - $200 for install - Total = $800 for hopefully that wonderful Lexus softness on the road.
Plus alignment of course.
if you're mechanically inclined AND feel confident you can work on your suspension, you can replace the shocks yourself. I'd keep the shock mounts if they show no sign of cracking - and on the LS400, the shocks aren't a pivoting point like on a MacPherson design - the shock is mounted onto the lower control arm - so there's no ball bearings in the shock mount to worry about. I'd change the shock boots if they are torn up.
I just did my rears last night, I now have GR-2s on all four corners. My ride is now firmed up, I also have 55-series Michelin Pilot Exalto A/S tires and Daizen polyurethane front control arm bushings too.
True, changing the struts is not too hard if you have the tools and the time. I helped my wife's brother change his (KYB) on his ES 300 and it was more difficult than my LS. It took us about 3 hours since we blew time on figuring out we were installing a front strut on the rear
Shouldn't mix beer with mechanics.
As for the inner and outer tie rods - if they are not loose I would opt to save the money. Sounds like you have a good contact in your mechanic. I would have him jack it up and check the tie rods before you buy them. I too was going to replace mine due to the age of the car however the units are still good and tight.
My wife's brother was quoted $900 to replace just the rear units
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
yeah bro. theyre not that hard if ur a DIY type of guy. i had a tanabe kyb set up on my old LS and wrecked it and i was qouted 1200 just to swap them out and 500 at another place and some place even 300 but still was too much for me. so i decided to do it myself and was fairly simple. once u get the hang of how to do one, u can do the rest easily. lexls.com will show u how to do the front ones. check that out and c if u feel confident on doing it.
oh and the kybs arent that bad they wer nicely stiff when new but once they get broken in u'll get a comfy ride. not to stiff. looking into the tokicos too. i hear theyre cheap in price but not sure about how they ride.
FitDesiGuy
01-06-16 05:38 PM
turbohonda
08-19-10 05:18 PM
