1997 LS400 headlight
Hi,
Does anyone has a pointer on how to open headlight assembly of 1997 LS400. I need to replace low beam lamp. This link does not have pictures.
http://www.lexusownersclub.co.uk/kno..._v2&id=191&c=7
I found 1 screw and two nuts. I removed them but it looks like parking light must come out first before head light assembly. Does anyone know how to remove parking light? Does it just pop out? I could not find any obvious screw for it.
there should be a screw on each parking light, after you unscrew that, just pop it outwards from the corner. to take out the headlight there should be 3 nuts, just look around the area, i would take pictures only if i had a camera :/. After taking out the whole assembly the headlight plastic seal in behind the assembly will likely come off and its a pain in the butt to put it back in. I just simply didnt put back in the seal, it should be fine.
Rollaboy
08-28-09 08:02 AM
OrangeCrsh
08-07-05 06:47 PM
