Sorry guys, another gas question?
Old 05-16-08, 09:27 PM
1995LS400
1995LS400's Avatar
Default Sorry guys, another gas question?
Early next month Im driving to Colorado Springs with my sister and her 2 kids to go see my brother (military). The trip 1 way is around 475 miles. Now Im not paying for the gas, she is. I dont want to rip her off by saying that I have to put 91 in, even though 91 is what Ive used since the day I bought the car.
Ive heard you guys saying something about "pre-ignition" with lower octane, but I will just be using the fuel for highway travel the whole time.....no gunning it. Do you see any problem with just this 1 time in the cars' life that it will be burning the "cheap" stuff.
Old 05-16-08, 09:34 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
best thing I would do is to just use 91 and pay 50/50...don't take chances
Old 05-16-08, 11:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
meh, i run 89 from time to time and it doesnt make much difference if you drive with a light foot anyways.
Old 05-17-08, 08:42 AM
19psi
19psi's Avatar
i would run the premium. i always run premium and i woudlnt' consider it ripping anyone off if that's what youalways do. now, if you never run it but decide you want to run it on the trip just because you're not paying for it, then maybe.
Old 05-17-08, 09:05 AM
LEX012006
LEX012006's Avatar
Had a 97 ls and ran 87 octane for about 60,000 miles and never had any pre-ignition issues. Most of my driving was highway though (100 miles a day) also drove south several times and vehicle ran perfect. No problems at all.
Now my 01 UL, I would have to admit I use the recommend grade (91 octane) but on a few occasions have use 87. And once again there was no issues when I ran 87.
Now in the owners manual, they state that you can use 87 octane for a short time, if 91 octane is not available!!!!
Old 05-17-08, 09:34 AM
cjmeyer
cjmeyer's Avatar
I use 87 on my 95 LS and it runs fine.Accelaration is not as strong but saving 30 cents a gallon is adding up.
Old 05-17-08, 10:20 AM
1995LS400
1995LS400's Avatar
That's the 10% ethanol stuff right?
Old 05-19-08, 06:49 PM
steveski
steveski's Avatar
True - good point as the manual states using lower grade gasoline is fine for a short period of time.
Old 05-20-08, 05:47 AM
sonyman
sonyman's Avatar
No, that's the regular stuff. However, in many parts of the country all 3 grades contain up to 10% ethanol. I remember when it used to be labeled as gasohol years ago. Now they just sneak it in.
Old 05-20-08, 09:49 AM
jcrome04
jcrome04's Avatar
You'll get worse mileage with 87.
You're not ripping off her you're ripping off your car.
You should be able to go +500miles on a full tank highway
Old 05-20-08, 09:59 AM
denverdog
denverdog's Avatar
i live in denver and have run midgrade (87!) for years. no knocking whatsoever. mileage is about the same. i do not drive the car hard. octane is lower here because the air is thinner and compression of the mixture is less. and colo spgs is a thousand feet higher than denver. life is better when you're high all the time.
i suggest you take your relatives to the broadmoor for sunday brunch. it is the best value in colorado.
Old 05-20-08, 12:52 PM
GSteg
GSteg's Avatar
A full tank of 91 will only cost $4.00 more over regular. Assuming you need 2 tanks to make a full trip, that's $8 difference......
Offer to pay the difference between premium and regular.
Old 05-20-08, 04:35 PM
Mugen_1
Mugen_1's Avatar
The users manual for the '97 LS400 recommends 91, but says that 89 with 10% ethanol is fine.
And where I live, the 89 is about 10 cents per gallon cheaper than the 87.
When I first got it, I was hesitant to put anything low grade in it, so I filled it up with Shell V-Power...then I read the manual and have been using 89 ever since and average about 20.7 mpg driving about 20 miles highway back and forth each day to college.
Old 05-20-08, 04:43 PM
docdgt@com
docdgt@com's Avatar
I have been using 87 exclusively for well over a year with no adverse effects at all. The performance "seems" the same, but if measured it might be a bit less. As to mileage, I get around 19-21 mpg in town and 24-27 on a highway trip with 87 octane. I have a light foot and my car is a '97 Gen II.
I'd say give it a good try and see what you think; I don't believe you will hurt your car one teeny bit.
Old 05-20-08, 07:17 PM
GKLCPA
GKLCPA's Avatar
I've been using 87 since gas prices went up with no ill effect. I plan to continue as long as gas remains at stratospheric levels.
Quick Reply: Sorry guys, another gas question?
