What type of headunit are you running??
#47
Crutchfield shows my 99 LS as "Euro-Din"...??
Anyone have some suggestions for medium range price (alpine,kenwood) HUs?
All I care about is good sound and aux input for mp3.
#50
I would say yes but also no, you would need to change the shape of the face plate (Just grind it down a few mil each side) due to the taper of the dash the lower u move it the less room there is for it to fit. Harness should be long enough, even if its not, not that hard to make it longer.
#52
I have the avic d3 in my car with ipod through the glove box and bluetooth and it works very well, i have not had a problem with it yet. Just get the double din kit from metra and it fits like factory. The one thing i could not find was a harness and no one makes one you might have to get a different sub with an amp like i did.
#53
did a quick bit of digging...
http://www.installer.com/item/displa...php?it=70-8112
notice it stops for the LS400 in '94...but meh, its hard to tell without comparing 1st gen and 2nd gen wiring diagrams which i am WAYYY too dead to do right now
![Doh!](https://www.clublexus.com/forums/images/smilies/doh.gif)
#56
because while there is physically room for a double din...there is no dash kit, the OEM stereo is larger than double-din.
I'd like to have a better idea what I'm looking for before I got to a stereo shop so I can be informed and not condescended to.
#57
So most people in the 98-00 run a 1 din? I can't seem to find pics of people's setup in the last gen LS400. I'd like do your aux-in hack PD but i'm afraid i'd botch the job.
#58
metra makes a dash kit for 95-00.
http://documents.victorytechnologies...duct/11631.pdf
the instructions show pictures of it being installed into a 95-97. the climate control area is slightly different in the 98+, but the bottom radio section should be the same.
i would definitely recommend going with an aftermarket radio. after i installed mine, the car just felt so much more updated and allowed for me to easily install a sub and amp as well as tune the sound.
#59
not too many people have headunits in the 2.5gen, and the only reason you'd need to worry about the headunit if you're doing my aux.in mod is if you have a nakamichi system, otherwise you have to intercept either behind the cd changer or at the amp under the passenger seat.
#60
