UCF-10 Headlights
UCF-10 Headlights
I was just wondering...the U.S. version 90-94 LS400 the low beam headlight bulb is an H4 size. I am waiting on the arrival of my JDM UCF-10 one-piece headlights. I hear they actually have a different size bulb for the low beams. Does anybody know the size?
If you have a UCF10 (89-92) then the low/high bulb is an H3 (9004 I think) bulb. If you have the UCF11 (93 and above) then the high/low bulb is an H4 and should plug right in without any problem. You bio says that you have a 98 LS. Anyways, 92 and under H3, 93 and above H4. The JDM light use the H4 bulbs, so you may have to convert the wiring harness to accomodate. Here is a thread which will help you acomplish that.
https://www.clublexus.com/forums/sho...jdm+headlights
If I remember correctly, the fog light is an H3C bulb. Pretty sure that I read that somewhere in the forums. Use the search feature. This topic has been discussed many times before.
naw. i have 2 1gen LS's and they are both stock 9004(high and low) i called and checked. and i orded my jdm headlights and those are H4's(high and low) and on the US fogs they dont make any aftermarket bulbs for the oem fogs. but u can easily convert them to h3c or h3s
hope that helps.
hope that helps.
OK, so physically I can mount the 6piece headlight set, head lights, fog lights, and corner lights from a 93-94 in my 90 LS just have to do some harness conversion? The physical shape of the light set do fit and bolt on right? or do the 93-94 not even bolt onto a 90??? Please advise . As for bulbs and harnesses I don't care as I am going to HID conversion anyway.
cool, wiring is not a big deal, so the 1993-1994 will bolt in fine right same shape and size? Mounts are in the same spots? I just have to convert the wires and harnesses right? I think I feel a mod coming on!!!
heres a thread i bookmarked for future reference, https://www.clublexus.com/forums/sho...jdm+headlights
With the Celsior's UCF 11 actually started in the same year as the UCF10 [1989], the 11 just meant air suspension , I haven't yet seen a UCF10 with air including ALL the LS400's that came into Australia , so they are all UCF10's , the next model were also all UCF20's , no LS400 in Australia from Lexus had air til the LS460 .
I have a 1990 Celsior and it is a UCF11 with air , so far haven't come across a UCF11 with out air .
For the Canadian LS400's the JDM headlights replace the USM ones directly , same bulbs , same wires , same mounts.
40 minute swap taking your time with an older car.
yeah, i had to do an H4 conversion for mine since mine is a 90. so i just ordered a harness to do the rewiring, that way if i ever need to go back to 9004 bulbs i still have my socket. i just pulled the harness off. and the JDM lights r sooo much simpler and easyer to install for some reason.
