Lower ball joint change for 1999
Here is a Hint for those who are about to do their lower balljoints. It'll save you PLENTY of time.
You do not need to remove the calipers at all. What you need to do is remove the (2) lower balljoint bolts first. Once you're done doing that, you can lift the whole assembly off; therefore, exposing the nut for the tie rod.
As for the dust shield bending, attach the tie rod first and then tighten the two bolts for the balljoints. That way the steering rack will lock up when it's turned all the way. You'll be able to tighten the bolts without bending the shield.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I dont know about the LS specifically, but if you have the ABS sensor wire attached to the shock body via 10mm bolt, remove that before you do anything, otherwise you might pull on the wire and rip it.
I saw this hint and would have done it, but I was replacing my rotors as well. Removing (or loosening) the 2 lower ball joint bolts first is a good idea, whether you remove the calipers or not.
All was going fine changing out the LBJ ,stuck the new one over the tie rod end ,was screwing the caster nut down ,and it just keeps going .It goes way past the hole where the pin is supposed to go .It is a genuine Toyota part that I bought ,compared it with the old one ,and they are identicle !!Why would it just keep pressing down on the ball joint .Is the nut not supposed to bottom out ?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thanks
Thanks
having seen the damage a failed LBJ can cause and the added stress on it from a lowered car, do you really wanna take the chance with an aftermarket (usually lower quality) part? personally until a rebuildable LBJ for the 2LS comes out i'll stick to OEM.
95-00 front lbj part no.s are 4333059045 for pass. side and 4334059045 for driver's side.
