changing my alternator
hey there is been forever with the ls seeing little to no road time with the sky high price of gas anyway ive changed alternators before but is there anything i should look out for or tips on changing the alternator in my firstgen ls it should be at my doorstep tommorow afternoon or nextday
It will be done from below. Take off serpentine belt. Remove one nut from top. get under car. Remove round plastic wire plug from alternator. Remove hold downs for AC pipes. Remove other bolt from bottom. Twist the whole alternator so that you can unscrew the second wire. Carefully manuver out the alternator. Its a tight squeeze. Kinda like your car having a baby....
Anybody ever hear the idiom "The only stupid question is the one that's never asked." Not going to kiss **** here, you guys should get a life besides picking on people asking simple questions.
Changing the alternator is a bit of cake. If you want instructions checkout my posts on here and other LS sites. Won't take you much over an hour unless you are a sucker for brews like me. Word of advice, if it is damp with oil it will be power steering fluid and you need the reservoir O ring replacing. Again it's a bit of cake & $3 and I've posted full instructions.
Dances with goats
MarcusMIA
Performance & Maintenance
12
10-03-16 09:46 PM
Devo83
02-25-10 04:09 PM
