I got a Big problem.. plz help.
#31
I actually replaced the sensor. I replaced everything that affects A/F ratio, and then some. I also done some experiments with the ECT sensor by unplugging it and plugging different resistors instead to fool the ECU into supplying more fuel, and it seems that with restance that normally means 60 degree when the engine is actually at 80-90 degrees, the car has much better acceleration, but it pings like crazy.
#32
it maybe good new for u in here
i change back my old altenator (it only charging 11.4 v bad) bc autozone did not have one yet so i have to wait until tomorrow
but i swap the old on back it run fine no problem idle fine every thing run good but it only charge 11.3 v have to ait until tomorrow swap a new one in , and wait for few days see anything going bad................
and find out the high pressure ps hose leaking slowly i guess i am go ahead and order on![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
well i been working last 4 days 8 hrs per day on my car swap ps pump altenator back and forwad, look for problem oil chage etc....very tired but at the end i am happy with it bc at least i fix some of the problem so i gues dont give up
very soon u will fix it
thisguy_06
RX - 1st Gen (1999-2003)
10-01-07 02:42 PM
