Ls400 audio setup thread (The Mother thread)
Old 02-03-12, 08:32 AM
  #256
LexGX
LexGX's Avatar
Sundown amps all the way
Old 02-03-12, 12:46 PM
  #257
PK_Celsior
PK_Celsior's Avatar
haha yes sundown amps all the way!!!
old setup!!!
Old 02-04-12, 02:42 PM
  #258
Vudugan
Vudugan's Avatar
Hello all, 93 ls400 all stock pioneer system to looking to do a minimal upgrade. Just want to say I mostly use car for work so not looking to have the best setup but for an inexpensive better sound then all stock has. I am looking to upgrade 8in sub and head unit and this is what I came up with.
Head unit
http://www.bestbuy.com/site/JVC+-+50...6#BVRRWidgetID
Wire Harness
http://www.amazon.com/SCOSCHE-TA02B-..._bxgy_e_text_b
Mounting/dash kit
http://www.amazon.com/Metra-Lexus-LS...ref=pd_sim_e_1
Thing is, I'm not sure about the sub woofer connection.. Is it a part of the wire harness already or is there another wire/adapter i need? I've read in previous post how they lost their sub upgrading head units. So again I want the factory amp to work with the new head unit and new sub. Is this possible? I also ran across this connector but really not sure if it applies..
Receiver Wiring Harness
For select 1992-00 Lexus and Toyota vehicles with factory amplifier
http://www.crutchfield.com/p_1207081...s.html?tp=2977
Old 02-06-12, 07:16 AM
  #259
McPierson
McPierson's Avatar
All of the speakers including the sub have wires that run from the amp under passenger seat to the speaker. There isn't a seperate amp for the sub. If you remove the stock amp and don't replace it you won't have a sub.
Most headunits have interated amps for the main speakers, but you'll need an amp to make the sub go boom.
Old 02-06-12, 08:50 AM
  #260
Vudugan
Vudugan's Avatar
Cool
Ok, so just to be clear.. . If I purchased all the above except the last wire, I should be fine? I will not be replacing factory Amp, at least I don't want to. Just hoping the new head and sub with factory Amp will be doable for better than stock sounds. Thx for your replies!
Old 02-06-12, 10:36 AM
  #261
McPierson
McPierson's Avatar
I'm sorry I must bow out on this one. I thought that if you replaced your HU that you would not be able to use the OEM amp, but it looks like that last crutchfield wire might work.
Hopefully someone else will step in and confirm if it's possible to use an aftermarket HU w/ the OEM amp.
Old 02-06-12, 12:15 PM
  #262
PK_Celsior
PK_Celsior's Avatar
there is a way to use an aftermarket hu w/ the oem amp. what you pretty much have to do is add in rca's into the stock harness. its not really worth it, because you can't adjust the gains on the stock amp. so it sounds really low.
Old 02-06-12, 06:01 PM
  #263
Vudugan
Vudugan's Avatar
Appreciate you chiming in Pk, so after market HU and aftermarket Amp is probably best....
Old 02-06-12, 11:17 PM
  #264
whit3b0y
whit3b0y's Avatar
BeatSonic is the easiest way to use aftermarket deck with stock amp. But its spendy.
Its cheaper to rewire with aftermarket amp. But its not easy.
Old 02-07-12, 12:24 AM
  #265
PureDrifter
BahHumBug
PureDrifter's Avatar
and still spendy
Old 02-07-12, 06:26 AM
  #266
McPierson
McPierson's Avatar
So what if one were to hook up the way you suggest, but instead of using the RCA out's use the speaker outs into a line-ouput converter. They are all adjustable and I'm pretty sure would increase the voltage of most RCA outputs.
Old 02-07-12, 10:16 AM
  #267
Vudugan
Vudugan's Avatar
I decided to just order the last harness posted just to see what happens. I haven't ordered hu yet but I'll repost my experience after installing.
Old 02-07-12, 10:51 AM
  #268
McPierson
McPierson's Avatar
Try my suggestion if it's really quiet when you hook it up.
Old 03-05-12, 07:00 AM
  #269
Live4brew
Live4brew's Avatar
Here are some pictures of my setup. I did this 8 years ago and tried to get some of the best components I knew of at the time. Since then, the amp has lost some channels, I've blown through a few sets of XRs, and the 8W7 lost it's foam surround (probably because it was exposed to the sun so much...even through the cover). When everything is working, it sounds awesome...and the 8W7 wallops in this configuration.
I didn't want to sacrifice much trunk space, so I built a box and amp mount that would be minimally intrusive. I don't remember the exact specs of the box, but I think it's around a cubic foot sealed. The box is bolted to the rear deck lid and supported by the amp mount underneath that is bolted to the trunk floor. Very minimal, if any, rattling from this setup.
As you can see from the pictures, the top of the box had to be built up (at an angle, no less) for the 8W7 to sit on top. The bottom also had to be extended to allow for the massive magnet the 8W7 has.
Attached Thumbnails Ls400 audio setup thread (The Mother thread)-000_0038.jpg   Ls400 audio setup thread (The Mother thread)-000_0039.jpg   Ls400 audio setup thread (The Mother thread)-000_0047.jpg   Ls400 audio setup thread (The Mother thread)-000_0048.jpg   Ls400 audio setup thread (The Mother thread)-000_0050.jpg
Old 03-05-12, 07:19 AM
  #270
Live4brew
Live4brew's Avatar
More pics:
Attached Thumbnails Ls400 audio setup thread (The Mother thread)-000_0053.jpg   Ls400 audio setup thread (The Mother thread)-000_0059.jpg   Ls400 audio setup thread (The Mother thread)-000_0062.jpg   Ls400 audio setup thread (The Mother thread)-000_0063.jpg   Ls400 audio setup thread (The Mother thread)-000_0070.jpg
Quick Reply: Ls400 audio setup thread (The Mother thread)
