Problem with the fuel gauge? '96
Old 06-22-08, 07:44 PM
en11871
en11871's Avatar
Exclamation Problem with the fuel gauge? '96
Hi,
This is what has been happening to my 2LS. Last week when I filled up I noticed that the needle does not go past F. That is always the case with any car when you fill up right? Anyway the needle is just at F. When I pulled away I noticed that the needle has already went below F...slightly, but below nevertheless. This happened again tonight when I filled up. I don't know if something is really wrong that is messing with my gas mileage or it is just the fuel gauge. Any ideas? Thanks.
Old 06-23-08, 07:15 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Most likely its the sender unit in the tank.
Went out in my 98LS, but did so in a more abrupt fashion. At first it wouldnt register past F, then it kept getting worse from there.
Bought a new one for less then 90 bucks and installed it myself (about 20 minutes, just make sure you have less then 1/3 of the tank in). The gauge became even more accurate, and the miles till refill reset problem in most 98's was fixed.
rjohns63
07-12-16 05:25 AM
Michael
03-31-16 10:19 AM
curepunx
07-20-09 05:02 PM
Blk97SC300
Performance & Maintenance
08-29-07 10:55 AM
praetorian180
Hybrid Technology
07-21-06 08:36 AM
Quick Reply: Problem with the fuel gauge? '96
