Sun roof problem
Old 07-01-08, 07:00 PM
fjstl
fjstl's Avatar
Default Sun roof problem
What solution is used to clean the sunroof mechanism on a 98 LS 400. I searched the site but I'm unable to find the answer to this question. It seems that my roof won't remain closed after pressing the close switch and when it appears to be closed, it opens immediately. I can press the switch until it closes and then it will remain shut. I want to try cleaning it before bringing it elsewhere. After cleaning, what do you use to lubricate it? A friend of mine had a similar problem with a different make of car and his mechanic cleaned and lubed it and it was fixed.
Old 04-12-09, 06:38 AM
smokincigs
smokincigs's Avatar
Did you ever get this to work right? Mine started to do it yesterday.
Old 04-12-09, 06:46 AM
fjstl
fjstl's Avatar
Default sunroof problem
no, the problem still exists. I just close it by pressing the close button a number of times.
Old 04-13-09, 06:34 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Interesting issue, never came across one before.
If there was something in the path of the glass, im guessing it would retract no matter what, so it could be an issue with the motor. I will test out my car to see whether the roof defaults to retracting despite holding the button down or not (windows will open back up no matter what if they sense something). This could help us identify the cause of issue.
Old 04-13-09, 09:07 PM
mista808
mista808's Avatar
this happened to my girlfriends car, but its an audi... same problem though.... i just openned the sun roof fully, cleaned both side rails, then sprayed WD40 to lube the rails, dont use any type of grease or white lithium grease cuz grease will attract dirt and clog the rails even worse....
Old 04-13-09, 09:10 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
WD40 attracts dirt. most petroleum based lubricant do.
use a silicone based spray if anything.
Old 04-14-09, 04:57 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Exactly, i've used silicone spray on my moonroofs for years with great success. WD40 strips the grease since it works as a degreaser
Old 04-14-09, 06:00 AM
fjstl
fjstl's Avatar
before using the silicone, what product was used to clean the side rails?
Old 04-14-09, 07:43 AM
Dereke
Dereke's Avatar
i used an engine degreaser and a rag to clean my rails out then motorcycle chain lube(silicone based) in the tracks. works great.
Old 04-14-09, 09:05 AM
fjstl
fjstl's Avatar
thanks and I'll give a try.
Old 04-15-09, 06:41 AM
Horsepwr
Horsepwr's Avatar
My 98 LS400 is doing the same exact thing . So all you guys are saying to do is just clean the tracks / rails ? The motor sounds perfectly fine ,so like you all are saying ,it just must need a good cleaning .Ill try that .Thanks
Old 04-15-09, 09:55 AM
smokincigs
smokincigs's Avatar
Mine is also a 1998. Pattern??
Old 04-15-09, 10:42 AM
Horsepwr
Horsepwr's Avatar
Id say !! Hopefully it is as easy as what has been mentioned in this forum .
Old 04-16-09, 03:59 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Wait a minute, i remember something about moonroof motor ECU re-calibration. These symptoms can be seen on side windows as well losing the auto-close feature. This often happens after a battery has been unplugged, replaced, etc...
If i remember correctly, you had to hold down the button and let it cycle (you have to be in park)... i cant remember exactly right now, but i'll search around for it.
For now, try holding any one button of the four of the moonroof controls and see if it will cycle through.
Old 04-16-09, 07:52 AM
fjstl
fjstl's Avatar
I haven't cleaned or applied the silicone yet but I do recall my problem beginning after a new battery was installed. I didn't notice the problem immediately because I wasn't using the sunroof much. I'll wait to see what you find out. thanks.
Quick Reply: Sun roof problem
