A/C filter location on 94 LS400
Hello-
New owner of a 1994 LS400, working my way through the typical maintenance stuff.
Could someone confirm the location of the A/C filter? I did a search and found nothing for the 94 model, closest info I could get was for an ES300 that showed it to the right of the accelerator pedal (LH drive models). Is the location the same?
In the 97 LS400 the filter is down by the glove compartment but can't find anything like that on the 94...except some small panel on the left wall of the glovebox that I haven't opened yet.
Thanks-
Rob
Thanks-
Rob
Got it
Ok, got it thanks!
There are 2 panels, one immediately below the glovebox and one below that is down by the floor. You want to remove the lowermost panel. I worked along the upper edge of the lowermost panel. There are 3 clips like you said. They're tricky to find but the innermost is about 3.5" from the innermost edge of the panel. There are slots for a (taped) screwdriver. Found them using a putty knife gently prying until I could see the slots. After you get the three clips then rest of removal is obvious. To anyone trying it, go slowly so you don't crack anything.
I pulled the filters and they're dirty. I don't think PO changed them at all, for 150K miles. I'm ordering new ones, can I run the a/c with no filters, temporarily, until the replacements arrive?
Rob
Rob
Are there any aftermarket filter replacements available?
I just took mine out and a bunch of dirt fell out with the filthy filters. Doesn't the air go through the main air filter first?? I am sure they were never replaced in 14+ years/165k miles.
I drove to work yesterday in Butte county where all the CA fires are happening and I was choking on the smoke that was getting in my car.
btw, I did mean the engine air filter, but I realize they can't be connected.
Retired
It is very simple to replace the cabin filter. Sit in the front passenger seat, and right where your knees nearly hit the dash, remove the cover below the glove compartment that is obvious by a large joint. Just use a flat screwdriver to carefully pry the top of the cover that is held in place by 3 backside clips. Then carefully bend the cover down, and pull it off the lower 2 clips. Easy. Then reach under the dash, and find the 2 wingnuts that hold the air filter support in place, and remove them. Pull off the support, and voila! you feel the bottom of an air filter. Then simply pull it down, and you will have 2 connected old small filters in your hand. Installation is simple, simply push the new filters into the plenum-they only fit one way, then repeat the reinstallation of the filter support and cover.
njamal
05-25-04 06:01 PM
