1jz mounts into ls400?
Old 07-17-08, 08:28 AM
driftfx1
driftfx1's Avatar
Default 1jz mounts into ls400?
well i'm new to the forum i was tryin to find out if anyone knows a company or someone that does 1jz mounts into and ls400. if so pm me or send me a link thanks
Old 07-17-08, 04:29 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
why do you want a 1jz? its going to be struggling hard against the LS' weight.
if you want a jz motor you pretty much NEED a 2jz, the extra low end torque will help.
and no, nobody makes any conversion kits for motor swaps into the LS.
welcome to ClubLexus, please search
Old 07-17-08, 07:27 PM
LiCelsior
Retired
LiCelsior's Avatar
yea what this noob said
Old 07-17-08, 08:43 PM
PureDrifter
BahHumBug
rofl, thanks Li
Old 07-17-08, 11:04 PM
skperformance
skperformance's Avatar
I wonder if GS300 mounts will bolt up to the block as they share the 400 unless they use different subframes which is hard to see be cost effective.
Old 07-18-08, 05:50 AM
JBrewster
JBrewster's Avatar
A 1JZ would move an LS just fine. A 1LS is only 300lbs more than a MKIII Supra. That being said, there's really no reason to go 1J over 2J in a car that the 1J was never used in.
Old 07-18-08, 07:45 AM
PureDrifter
BahHumBug
the LS has much taller gearing than any supra.....both in rear end and in teh trans.
and a 2LS is decently heavier than a 1LS...
and the 1jz, which was NEVER used in the supra, produces a lot LESS torque, especially at the lower end where you need it for a heavy car, than the 2jz.
some members have messed with later model vvti mounts....but no confirmed fitment.
Old 07-18-08, 07:48 AM
plex
1UZFE/2JZGTE
plex's Avatar
The 1j was used in the JDM MKIII Supra
Old 07-18-08, 08:05 AM
driftfx1
driftfx1's Avatar
i found a full vvti swap for less than a $1000 so i said y not.
Old 07-18-08, 08:07 AM
JBrewster
JBrewster's Avatar
You wouldn't use the LS's transmission if you swapped in a JZ. Last I checked a 1LS weighed 3850 and a 2LS weighed 3650, is that wrong?
Either way the 1JZ with stock turbos has enough low end power for an LS. And it did come in the Supra in Japan. I had swapped a 1J into my Supra and had a final gear ratio of 3.73. Even with a couple friends in the car, it had plenty of go. Those small turbos spool up very quickly. Given I don't know the final gear ratio in the LS, I doubt it's super low since it uses a version of the A340 transmission.
Old 07-18-08, 08:26 AM
driftfx1
driftfx1's Avatar
na i'm using the same tranny it comes with auto but who cares all i'm gonna do is daily it.
Old 07-18-08, 08:44 AM
PureDrifter
BahHumBug
1LS rear ratio is 3.62:1
2LS rear ratio is 3.27:1
1LS weight is ~3851lbs
2LS weight is ~3890lbs
http://www.lexus.com/contact/pdf/1993/1993LSspecs.pdf
http://www.lexus.com/contact/pdf/1998/1998LSspecs.pdf
jz motor wont bolt to uz trans
Old 07-18-08, 09:00 AM
runumhard
runumhard's Avatar
my friend did a swap in his sc300...2jz.... and it's for sale
Originally Posted by dednah-der
im not going to list the full details, but if you are seriously interested, i can email you full details and pics. i dont want to waste time with people who dont got the funds. heres the basics.....
-1992 maroon lexus sc300
-tan interior
-COLD AC!!!!
-us spec 2jzgte w/6spd trans, autronic standalone, t04z turbo, supra subframe, supra brakes, etc etc etc. 635whp 550tq
-tein flex coilovers
-19'' te37 time attacks
-recent safety and registration
-power everything
bads - body has some dings here and there, nothing major. front fenders were pulled and rolled, so some people might not like the look. will include another set of stock fenders.
there is alot more details to list that the car has. bottom line, the car is stupid fast, has cold ac, everything works, will run high 10's with traction, doesnt leak or burn oil, car runs very cool, daily driver all day everyday with zero problems.
more info or interested? PM me. ive put alot of money into this thing. reason for selling? i think i am getting too old to be playing with cars. there are other things in life that i want to do, but need to raise money to do so. anyone who knows me, will tell you that i didnt take any shortcuts with this car.
$18,000 obo
Old 07-18-08, 01:22 PM
driftfx1
driftfx1's Avatar
thread jack ftl
PoGikoSc4
Southeast
02-08-11 01:57 AM
dirtyhands
Performance & Maintenance
03-03-07 07:11 PM
supraglen
SC400 / 300 Classifieds
06-06-06 10:40 AM
Rising_Sun
06-05-06 10:31 AM
Quick Reply: 1jz mounts into ls400?
