Solar Sensor Replacement? A/C Related
Anyone ever do this operation on a 1st gen?
The A/C is blowing cold on the right side vents and warm on the drivers side vents. I ran a A/C diag and received code 21 w/o any beep. I'm wondering how to test or replace the sensor/ circuit? Thanks in advance....
As per the Lexls.com website, the most common reason for that fault is... you're in your garage and it's somewhat dark.
I doubt that sensor is actually your problem. Try the diagnostics again in the sunlight to see if that eliminates the error code.
Good luck.
Good luck.
