Will 225 40 18"s fit my 99 LS 400 came off of IS 300
Wanted to know if 225 40 18's would fit my 1999 lS 400. These tires and rims came off a IS 300. Please let me know what you think and any possible issues. Thanks in advance.
Big, those wheels will fit without a problem. Actually it is gonna be a little on the small side. I run 235/40/18's on my 92. Could have run bigger, but wasnt in the market at the time.
May want to test fit them first, because I don't know if your calipers will clear the offset from the IS wheels.
Diameter is too small. I'm running 245/40-18 all around on mine. And, I believe that's even slightly shorter than the factory diameter. Original 235/45-18 per tirerack recommendation was too tall and rubbed on the inner fender lining up front.
As others mentioned, not sure on the wheel fitment (i.e. offset).
These are after market rim not sur of the manufacturer with federal tires. The only reason im pressing it is because i need tires bad and I can get these in great condition for under $500. Thanks to everyone, it sounds like i will need to try these on because of the front brake calipers.
sydwys
SC- 1st Gen (1992-2000)
14
02-02-08 01:42 AM
EyeKutr
10-09-07 06:09 AM
SpinAll4
Suspension and Brakes
07-31-07 11:00 AM
