Changing spark plugs on 2000 LS 400
My friend had decided to change spark plugs himself on his 2000 LS 400 and now has difficulty with completely removing them. If anybody has done it, can you please share the information about needed tools? Any help will be appreciated.
puredrifter has a detailed FAQ for the 2LS owners... and its stickied on the top of the forum. https://www.clublexus.com/forums/sho...d.php?t=264122
and for 1ls steps, http://www.lexls.com/tutorials/ignition/sparkplugs.html
Yeah spark plug socket with the rubber insert and a 6" extension is definitely necessary when I did mine. The spark plug socket grabs the plug in the rubber so that you can get it out.
Aluminum block/heads or not it still gets really hot. Atleast you don't have wires like I do on my 95!
Also most plug manufacturers say to not lube the threads and torque values are small (less than 20 ft. lbs) as I recall on my Denso's.
Thank You All for great help. The only question remains is how to remove the black rubber part which sits on top/around of the spark plug and prohibits insertion of any tools to remove it. My friend does have all the tools but can not use it due to the new design obstacle.
sparkplugs.com they are under $10 a piece.
I just changed my plugs and wires out the other day on my 97. OEM wires and Denso Iridium Long Lifes. SK20R11s.
It takes a while digging through all the plastic to get to them but it's easy peasy!
I may have to do this myself in a couple of months as the guy I talked to was wrong...
bradland
05-27-09 11:53 AM
