Hey guys, and girls, I have a weird instrument cluster question for ya
Ok, here is goes. My instrument cluster had the typical issues: temp gauge "stuck" in the middle position (no matter if the car was on or off) and needle burnt out, tach was slow, needle burnt, and fuel gauge burnt and inoperable (the gas light would come on above the 1/4 mark) . I sent it away to BBA-Remanufacturing to have it repaired...they said the actual temp gauge "pod" (for the lack of a better way for it), along with the fuel "pop" had to be replaced. They did that, and fixed the tach, and all needles. Lifetime warranty. So thats good!
Here's my current issues. I am concerned, not for any good reason though, about my engine temp. Maybe I am paranoid, but I check the temp ALL the time. The temp guage does move now, all the way up to where is it was previously stuck (and goes to '0" when car is cold/off). The fuel gauge is BETTER, but still comes on far too early. Should I assume that the temp guage is still inaccurate, is there a way I can drive the car for awhile, and get a physical temp reading?
Do out UZFEs have a tendency to run hot? Not in a bad way, but by nature? Corvettes have a 5.7L that runs very hot, but totally normal. Whenever Im sitting at a red light with windows down, a/c off, arm out the window, I get these really hot "waves" of air that come up. Once again, I might be paranoid, but while driving YOU LS's, does your temp flucuate, or does it stay pretty much at the exact some spot the whole time driving (I rarely punch the gas or really get on it, so maybe thats why my reading shows to be super consistent?
Sorry this is SO drawn out, but if you did read the whole thing, I applaud you and thanks! Any input would be great!
-Ian
-Ian
Thanks for the super quick response, PD..
To clarify, so I do the right thing... would what you said to do be the same as "burping" the cooling system? i.e. taking off the cap and running it until possible air bubbles come to the surface?
Once my car warms up to operating temperture, it pretty much stays there and doesnt move. My needle, like yours, stays almost in the middle of the gauge. I too feel the waves of heat sometimes, but it has never been a problem. At cold gauge drops to the bottom, like it should, and then moves upward as the car warms up. I think your gauge is fine.
I personally think you're in the safe zone.
I wouldn't worry too much.
