DIY Coolant Temperature Sensor change (PICS)
Old 01-05-14, 08:41 PM
  #196
qha_vn
qha_vn's Avatar
this tutor is exactly what I have been looking for. thanks for the efforts outting to this. il do this shortly, already got after market sensor replacement.
Old 01-06-14, 04:39 AM
  #197
AtlasLS400
AtlasLS400's Avatar
Go with the OEM sensor
Old 01-06-14, 05:12 AM
  #198
LScowboyLS
LScowboyLS's Avatar
Originally Posted by AtlasLS400
if that is indeed an Ohizumi (NTC) part and the seller is not pulling a fast one, then you should have the genuine OEM part, as they are the OEM, please see my master Toyota OEM list
Old 01-06-14, 06:33 PM
  #199
qha_vn
qha_vn's Avatar
i love OEM parts but not all the times they love me. so i have to go with 3rd party most of the time :-)
Old 01-06-14, 10:43 PM
  #200
CaseyA98
CaseyA98's Avatar
All-
Well I finally completed the task last night, it took me about 1.5 - 2 hours. Being very picky about everything and careful knowing that the car isn't new and all the parts aren't 2 months old, I just wanted to be cautious...WOW, After I got this done, It was the FIX ALL for all of my high start up idling problems. I CANNOT believe how much better the car runs, as we get to know how we drive our cars with out really paying attention to the speedometer, where I'd normally be going 60 MPH with my gas pedal in place, this AM I was going 75, it was like a rocket busted into the engine. When I went to heat up my car (the true test) Started her up, RPM's were around 1150-1200, mind you all on a cold frosty 28 degree morning. Last week the car would have been ar 1950-2k RPM for about 10-15 mins as soon as the car got too temp, and then slow to a normal idle. I couldn't be happier, I have no idea what Lexus would have charged me (and the 1.5 hr drive to the dealership) but I can now cancel my appointment I have on Friday, or just take her in for an oil service and mini inspection.
Anyhow, I just wanted to share my excitement and thank everyone for their thoughts and options and PICS on this task, I'd say that anyone venturing out to do the task, steam forward and get it done, it's a great way to familiarize yourself with the engine of your car..Also better note, I did not end up using an OEM part, which was really hard for me not to do, I called the Toyota dealership that's closer to me and the parts guy informed me that he'd recommend using the non oem a
s he felt it was a better choice, that being said I picked one up at my local NAPA store, for $38 with a 3 year, 36k warr. on the product (could have bought one for $26 that had a 2 year 24k warr.) we'll see how it goes, but again, so far so good. I'm still amazed. Looks like she's ready for ANOTHER 190k! )
GOOD LUCK
Old 01-28-14, 08:52 AM
  #201
BeLSNow111
BeLSNow111's Avatar
Originally Posted by LScowboyLS
it's not 70 if you shop it around online, more like $50
in fact, here it is for $41 to your door
Is this the ECTS for the 1996 LS400 as well? I had been searching ******* for the part number and could not find the ECTS on their site so I am unsure.
Old 01-28-14, 10:11 AM
  #202
RA40
Super Moderator
RA40's Avatar
Yes part# 8942220010 is the one.
Old 01-28-14, 11:04 AM
  #203
BeLSNow111
BeLSNow111's Avatar
Thank you! The water temp sensor is aka the ECTS? Thanks for helping me clarify this! No wonder I have not been able to find 'ECTS' listed as a part in any catalogs.
Old 01-28-14, 12:23 PM
  #204
LScowboyLS
LScowboyLS's Avatar
Yes, the Engine Coolant Temperature Sensor (ECTS) part number 89422-20010 is the green one below and the one that feeds the ECU so that it can make correct decisions on how to run the car correctly for the conditions - beside it, you have the gauge sensor (gray sensor below) which only is for the gauge in the cluster, and then there is a sensor in the bottom corner of the radiator for the electric fan.
Old 01-29-14, 09:46 AM
  #205
BeLSNow111
BeLSNow111's Avatar
Thanks for posting up this image, helps me a lot!
Old 02-03-14, 04:19 PM
  #206
xXTACOXx
xXTACOXx's Avatar
mine literally crumbled into pieces . took 10 minutes. i can definitely see a mileage improvance
Old 02-07-14, 11:57 AM
  #207
MattLS400
MattLS400's Avatar
How critical is it to have the
1 Wire Sensor for the gauge and the Sensor to the bottom of the radiator changed ?
My 1996 Celsior (UCF21 with stock 1UZFE) has a Hydraulic Fan, but Im currently experiencing a dip in my RPM once the Engine is heated (Hal temp level)
Please see post # 1
https://www.clublexus.com/forums/ls4...s-to-half.html
Old 02-07-14, 01:44 PM
  #208
LScowboyLS
LScowboyLS's Avatar
the one wire sensor only affects the gauge accuracy - it has nothing to do with how the car runs or what temperature it runs at
Old 02-07-14, 10:18 PM
  #209
MattLS400
MattLS400's Avatar
Ok very well...What about the sensor to the bottom of the radiator? I would still like a part number please
Old 02-08-14, 12:13 AM
  #210
LScowboyLS
LScowboyLS's Avatar
The temperature switch (not a sensor) at the bottom of the radiator - part number 89428-33010
Quick Reply: DIY Coolant Temperature Sensor change (PICS)
