LS400 HID Install Problem (1st gen)
i hate to go off topic and bring it up but its been one day with my hids........love then but cant find a good permenant spot for my ballast's....where did other you other 1st gen guys put them??
thanks.Gdave
thanks.Gdave
i mounted one on the pass side to an empty bolt hole that i had since i remove dthe stock air intake pieces for my HKS filter.
the other one i think i stuck betweenthe battery and fuse box cover with 3M body tape.
Sorta stealing the topic, but I'm about to get an HID kit for my '92.
cheesey said he installed the JDM lights, and thus has the H4 bulbs, I assume? I'd like to get a kit that does high/low beam since I hit unlit roads often. Anyone know if I'll still need to do extra wiring if I get a 9004 HID kit for mine, or would it actually be plug and play?
pt your own fuse in! its easy... the fusebox is on teh drivers side front fender. just pop the hood and look for a rectangular black box with 2 phillips screws on top. under the cover is a label telling you fuse locations.
you can't use the stock headlight plug if you are using a hi/low hid kit because of the way toyota designed the lighting circuit.if you hit hte high beam switch, it will blow fuses every time.
you have to make your own circuit or forget about high beams. i chose to forgo the high beams since they didn't really seem necessary anymore.
wow this thread is old.
I'm planning to purchase an hid kit from ddmtuning.com (a lot of bimmer guys buy from them). It'll be a true bi-xenon. Will i need a relay harness so that when i turn my high beams on it won't blow the fuses? Should i get the relay harness anyways so that i don't melt my factory harness?
Even the Hella Supertone horns I had on my previous LS sounded wimpy unless I powered them from the battery with a relay and connected a wire from the relay to the existing horn wire to trigger the horns to sound when I pressed the center pad of the steering wheel.
May sound complicated but it's not.
