Power Steering Leak on '95...
Old 09-21-08, 09:44 PM
B-b0y
B-b0y's Avatar
Default Power Steering Leak on '95...
I'm having to fill my power steering fluid about once a month and just noticed the puddle in my driveway. From the looks of it... it's coming from my power steering resevoir. Is this a common problem w/ this year? Gonna try and track down the source, but just curious if there's a quick fix for it for those that may have dealt w/ this problem already...
Old 09-22-08, 05:56 AM
eg6ky
eg6ky's Avatar
I have heard of the hose having to be replaced. Ebay has them.
Old 09-22-08, 07:35 AM
B-b0y
B-b0y's Avatar
The hose coming off the bottom of the resevoir?
Old 09-22-08, 08:08 AM
ffcgary1
ffcgary1's Avatar
Default p/s leek
The leek is prob the small o ring on the p/s res where it enters the pump, it is a common fault and one that i have to do, as mine is leeking but not as bad as yours. Get it done soon as the oil will trash the alternator that sits right below it. A cheap fix but a bit fiddly.
Old 09-22-08, 09:30 AM
RA40
Super Moderator
RA40's Avatar
If the alternator isn't getting the fluid, you have a bit of leisure time to get it fixed. If it is getting soaked...take care of it ASAP. I had mine resealed (new o-rings) and such for like $180.
Old 09-22-08, 04:04 PM
ffcgary1
ffcgary1's Avatar
The 0 ring cost me £O.50p sterling [about a doller to you guys] and it should only take about an hour to do after you have sucked all the fluid out of the res tank. an easy diy job.
Old 09-23-08, 11:39 PM
B-b0y
B-b0y's Avatar
Thanks guys. Don't suppose you know the part # off hand for the right O-ring and if I can get it at Autozone or not, do you? Can't seem to find it anywhere...
Old 09-24-08, 02:19 PM
ffcgary1
ffcgary1's Avatar
Default part No
I will try and find the o ring plastic bag from my garage tomorrow eve and post up the details for you, if not your local dealer will have it. The part no that i bought was for a 93 gen 1 but i think that they are all the same.
Old 09-24-08, 09:33 PM
B-b0y
B-b0y's Avatar
Awesome man! Yeah, lemme know if you can, thanks...
Old 09-25-08, 07:20 AM
ffcgary1
ffcgary1's Avatar
Default part no
The part No for the p/s res tank to pump body is 90080-30040 and that is a toyota part no so they should be able to supply it to you. The parts guy did also ask for a chassis No to cross check fitment but as i said this is for a 93 gen1 car but they should be the same through the range years. Lets hope yours is just the o ring not anything more extensive but hey ho start at the basics and work through the possabilities.
Old 09-25-08, 09:48 AM
B-b0y
B-b0y's Avatar
You da man!!
Old 09-25-08, 10:01 AM
Lex-luger
Lex-luger's Avatar
Wink
Ok, slow it down...take a deep breath...and let's hope for the best! Here is what I can tell you with my experience on my '98 LS 400: I had the same problem. Couldn't quite pin-point where the leak was coming from, or why. Well, after my alternator burnt out from power steering fluid leaking on it and blowing roughly $400.0+ dollars, I then focused my attention the leak (I kept replacing fluid as well, dumb/lazy move that eventually costed me $$$). Low and behold, it was coming from the resevoir alright, the BOTTOM of the resevoir where the hose connects and the fluid runs through. What it actually was, was a cheap-*** plastic clamp that wasn't CLAMPING correctly anymore! Can you believe that? There was no problem with the resevoir, or the hose itself, rather the clamp that connects the hose with the resevoir. Try clipping off the existing clamp and replacing it with a metal, phillips head screw-tight/down clamp...runs 'bout a buck or 2 for the little clamp. Clean out the area completely (the resevoir, the hose where there is build up), then run it for about 15 minutes....if it is dry and clean, that was the problem. Mine hasn't leaked since......good luck~Lex-Luger
Old 09-25-08, 08:56 PM
B-b0y
B-b0y's Avatar
Very interesting. Well I ordered the o-ring today from Lexus cuz it was only $2 (should be in tomorrow), but I'll def check out the clamp when I'm down there lookin' around for its condition. Good lookin' out man!!
Doc Yota
12
04-17-20 01:31 PM
N00bie909
SC- 1st Gen (1992-2000)
11-05-09 06:50 AM
LEXUSver
Performance & Maintenance
10-12-08 05:59 AM
PxH_83
Maintenance
05-05-05 04:34 PM
Shaffer
11-29-03 08:39 PM
Quick Reply: Power Steering Leak on '95...
