Gonna do a coolant flush 93 LS400 - temp question.
Old 10-10-08, 08:56 PM
chrisngo
chrisngo's Avatar
Default Gonna do a coolant flush 93 LS400 - temp question.
Hey guys,
Where does your temp needle sit after about 30 minutes? Mine sits right in the middle or slightly above, is this normal?
Chris
Old 10-10-08, 10:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
30mins of driving or after you turn it off?
Old 10-11-08, 03:40 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Mine sits slightly below the middle after it's warmed up.
Old 10-11-08, 05:16 AM
Bradster
Bradster's Avatar
Ditto on the above..
Old 10-11-08, 06:12 AM
LiCelsior
Retired
LiCelsior's Avatar
mines in the middle.
Old 10-11-08, 09:52 AM
RandomHero
RandomHero's Avatar
Mine is in the middle as well.
Old 10-11-08, 10:20 AM
jcrome04
jcrome04's Avatar
My 97 is just barely over the........... second notch I believe. Not quite exactly in the middle..
I can't remember 100% lol
Old 10-11-08, 03:03 PM
chrisngo
chrisngo's Avatar
Alright. Thanks for all the responses. Hopefully it'll sit a bit cooler after it's changed. *crosses fingers*
Old 10-11-08, 05:28 PM
FLIPMOE
FLIPMOE's Avatar
Same here and i have a '94 LS
Old 10-19-08, 03:09 PM
Bill Dowd
Bill Dowd's Avatar
When you change your radiator fluid I just drain my radiator and engine block and then I add the antifreeze. I USE TOYOTA ANTI FREEZE 2 GALLONS ALSO I MIX IN 2 GALLONS OF DISTILLED WATER MIXING IT 50/50 I END UP WITH 4 GALLONS AND I GO AHEAD AND FILL UP THE SYSTEM I DO THIS EVERY 2 YEARS. MY 91 LEXUS HAS THE ORGINAL HOSES--RADIATOR WITH 212,000 MILES AND NO PROBLEMS. THE PEOPLE AT LEXUS TOLD ME HOW TO DO THIS. I DO NOT FLUSH OUT MY SYSTEM DUE TO HARD WATER HERE IN CALIFORNIA JUST DRAIN AND FILL.
Old 10-19-08, 04:06 PM
python
python's Avatar
be careful not to get an air bubble in the system or it will run hotter than it should
Ron81
06-25-17 04:33 PM
fade41
01-16-16 11:52 PM
GX470GT
05-10-11 09:22 PM
micell2
Maintenance
22
03-06-05 06:22 AM
LS4Lexus
Maintenance
11-11-04 11:50 PM
Quick Reply: Gonna do a coolant flush 93 LS400 - temp question.
