Inside tire wear ?
Thanks for all the replies guys, I'll take it to another shop this weekend to see what we get, and yes they had all the sensors mounted up and the specs are for a 1991 LS400 without air suspension. The spec sheet from my car is as below:
ther'es your problem. never go to that shop again until they hire an alignment guy who knows how to read the numbers!
look at your front toe.
left front=-0.05 right front= -0.01
look at the specified range. it's 0.00 to 0.20.
yoiur front toe is out of spec!
caster = 9.17
toe in =0.04
all measurements in degrees Download the settins from the workshop manuel and take the fig to the allinment shop and tell them to set at thos specs.Oh and while your at it ask the original shop to replace the shagged tyres as they cocked up the job.
incorrect toe causes the most tire wear of all suspension settings. even small amounts cause wear espeically if htey're not even. since one side is different from the other side, they are essentially working against each other and the steering wheel causing more wear than simply the one tire out of spec alone would.
UCrazyKid
IS F (2008-2014)
18
09-14-15 04:35 AM
