bad ground wire!!
Old 10-15-08, 05:25 PM
dedott21
dedott21's Avatar
Default bad ground wire!!
i have been reading about the treads here on this site about the trunk wires making the car acting crazy!!!well i found the problem that was causing my car to act that way!! the altenator ground wire is bad and corroded!!!! as soon as i step on the pedal,it loses power but if i've drive normal its ok!i've called lexus and they want to sell the whole wire harness for a 1,000.00 dollars for the harness but the junkyard wants half for that,also!! does anyone know a way that i can replace or splice the wire with an battery cable??? i need help,going on a road trip this weekend!!
Old 10-15-08, 05:54 PM
farquad
farquad's Avatar
if it's a wire.. can't you just replace it.. clearly i know nothing about the trunk issue other than them being a major pain
Old 10-15-08, 08:27 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
lextreme sells low gauge alternator cables maybe those could help.
Old 10-15-08, 09:07 PM
dedott21
dedott21's Avatar
thanks ,i'll go there to check!!!!thanks a lot!
Old 10-16-08, 06:41 PM
dedott21
dedott21's Avatar
i'm going to take your advice about the trunk wires this weekend,because the ground wire wasn't the problem!!!i will check my plugs,its driving me mad!!!!!
Slickcam
GS - 1st Gen (1993-1997)
15
02-04-16 03:15 PM
LexBrett
05-19-15 12:02 PM
arcteryx
01-14-15 07:52 AM
kensteele
05-20-08 07:11 PM
mjr24
SC- 1st Gen (1992-2000)
09-19-02 12:02 AM
Quick Reply: bad ground wire!!
