Ls400 Rear End Noise?
94' 170k Miles When I Let Go Of The Brakes Quick The Rear End Makes A Loud Sound Like Its Caught On Something Or Something Like That
Have Any Of You Experienced This? Ill Be Working On It Sunday So Ill Know For Sure Just Wanted To Check And Se If U Guys Might Know The Scoops....alohah!!!
Depending on the type of noise. It could be the trailing arm bushings since this is a common issue. This can make noise while accelerating and braking. Jack it up and try and move the rear wheel from left to right back and forth. if there is movement look at the lower bushings on the spindle. If this is the issue there is a nice bushing kit out there from Daizen. If it is not the issue try to post up as much info as you can if you cant figure it out.
yes thanks its the rear axle carrier arm bushing....fricken bust *** job thanks boys....
heres a link:http://www.lexls.com/tutorials/suspe...abushings.html
