Brake question-95 LS400
Old 10-24-08, 09:20 AM
LiCelsior
Retired
LiCelsior's Avatar
Originally Posted by ryanSC300lover
I am not sure to be honest. The noise isn't horrible by any means. I am just very **** about things.
Joe-I ended up picking up a new Range Rover for the kayak duties.
niceee, supercharged?
Old 11-17-08, 05:13 PM
ryanSC300lover
ryanSC300lover's Avatar
Yes Joe, Orange SC.
Old 11-19-08, 08:59 AM
burghard
burghard's Avatar
Back to ryansc300lover question, squeaking in front and soft pedal. I have had similar symptoms on my 94 LS400. Found out that the brake caliper sliding pins were stuck causing the pad to only grab one side of the rotor. Got them working again, replaced pads and everything was fine.
Old 11-19-08, 09:02 AM
ryanSC300lover
That is interesting. Yesterday in the work garage, the brakes were squeaking again pretty bad (fronts only), since I have everything new in the rear. Lots of meat left in the pads. You might have a point there. Hmm ok will check it out.
Thanks!
Old 11-19-08, 10:42 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
Thanks!
but the fronts are floating calipers
you did put in the right shims? what pads did you end up with?
Old 11-19-08, 11:38 AM
ryanSC300lover
I didn't end up changing anything in the front. Took the wheels off to check, there is about 75% pad left. All OEM.
ak11
Wheels, Tires & Brakes Forum
04-12-13 09:45 PM
sidwin
Suspension and Brakes
09-22-12 09:46 PM
Edmo83
Great Deals
03-25-08 06:53 AM
jahummer
Maintenance
08-06-02 02:11 PM
Quick Reply: Brake question-95 LS400
