Lights out
What are you trying to do?? Change the bulbs or convert to the JDM headlights? Fairly easy job to do. Remove the screw on the top corner to remove the side marker lights. Pop these off and then it is only 3 aditional screws to remove. One on the side behind the side marker,,2 on top,, and one at the base of the headlight at the bottom (closest to the grill area).
This should help,,,
https://www.clublexus.com/forums/sho...dlights+wiring
This should help,,,
Tonyucf20
20
01-07-17 10:45 PM
