Bearings replaced for serp. tensioner and idler pulleys. Part numbers.
#92
I found the replacement for idler pulley , its part # NSK 70SPPV0408DDUL the pulley is the same and it has the same exact bearing NSK BD20-15DUL whit a solder
I see them on Amazon for $36 and few more $ on Ebay
#93
I called the bearing shop for a cross reference and he relayed this site for me:
http://www.consbrgs.com/index.html
Bearing search database:
http://www.consbrgs.com/search.html
#94
Generic SKF or other make bearings also work well. I used SKF.
This is pretty standard Ballbearings with double sided rubber lip seal typically generically named 2RS and a sligthly increased play which is typically generically named C3. The reason for the slightly larger play needed is that when assembled with press fit it will be correct beacuse the outer ring is slightly compressed. Hence 6301 2RS C3 or 6203 2RS C3 is the generic bearing names fot these NTN bearings.
IF you buy a bearing with standard play ( not marked C3 on a generic named bearing) it will typically at least often be too tight. I did that. Ran tight with resitance and did not feel good. Redone with a C3 Bearing it worked fine.
#95
Hi
I have also exchanged these. It was necessary. Really dry sounding. If you change for bearings designed for this car they should be ok.
These bearing are standard mm size. You can pick them up from many vendors cheap. I paid 8$ However if you do see to that you get known brand, double sided rubber seals and C3 play at least. C3 or other similar designation means bigger then normal play in the bearing. This is needed since the bearing have a press fit outer ring and will loose play when mounted. I made that misstake and it was tight and rotated a bit heavy. Not a good idea. Did it again with a C3 type and could feel a small play which is fine. Risk for fast wear out when too tight. I used a bench wise and sockets to press in/ and out
I will check when I take this thing apart tomorrow.
Thanks again! Great work.
#96
Hi
https://www.mcmaster.com/bearings/ba...ball-bearings/
Oomfh
03-06-19 11:14 AM
YODAONE
02-06-17 02:02 AM
