tick tick goes the 4.0 ?
#32
You can distinguish between exhaust leaks and valve ticking by how the noise changes under load. Exhaust will get worse under load, and is commonly worse when cold.
I went through the valve adjustment procedure as mentioned earlier up in this thread and elsewhere. I had the noisy tacktacktacktack at the left rear intake area. Adjusted the valves . . . carefully. Tacktacktack came back, wtf?
Tore the valve covers off again, and this time removed the camshafts (replaced the timing belt while I was here as well). UNDER the #7 intake lifter bucket was the culprit . . . the valve stem was shellacked with goop and there was oil starvation between the valve and the lifter bucket's hardened pad. The clearance had opened up over .010" of an inch. You could see the valve stem trying to drill its way through the lifter bucket. Replaced the bucket, adjusted the valves reassembled this mess, and have enjoyed well-lubricated whisper hush serious V8 performance ever since. The work is quite easy if you are well focused and methodical:
![](http://i187.photobucket.com/albums/x133/73VW1800/Lexus/lexusTBelt016.jpg)
![](http://i187.photobucket.com/albums/x133/73VW1800/Lexus/lexusTBelt013.jpg)
![](http://i187.photobucket.com/albums/x133/73VW1800/Lexus/lexusTBelt015.jpg)
#33
#34
Great info. Amskeptic. Are you saying there was thick varnish/sludge of some sort under the lifter bucket that blocked oil circulation? Your valvetrain looks clean to me so I wonder how that goo happened? Previous owner stretched oil changes?
Also, did you get a new lifter bucket from the dealer or a junkyard 1UZ-FE? Any fitmint / clearance issues using a new lifter inside a worn lifter bore? Thanks.
#35
The PO was a short distance winter commuter in NYC. Synthetic oil may be less prone to leaving these goopy deposits that prevent what is somewhat poorly engineered splash lubrication between the stem tips and buckets. New bucket was $13.00 from Sewell Lexus in Dallas (no way I would use used parts inside of these beautifully precise engines), it fit fine in its bore. Change your dino oil frequently in winter if you are a short-drive commuter and I think you'll be fine. I refuse to start the engine unless it is getting a good full warm-up work-out. The entire lubrication system and exhaust runs have to get above 200* to evaporate the acidic exhaust condensate in all of those crankcase/head passages and in those expensive silencers and joints.
Colin
robbyk
09-29-17 01:12 PM
Lexarse
Performance & Maintenance
07-11-05 06:50 PM
