98 LS Brake Clearance Question
Old 11-23-08, 12:36 AM
black_LS
black_LS's Avatar
Default 98 LS Brake Clearance Question
Looking at buying some wheels in 19x9.5 +45.
Will they fit without spacers?
My current 18x7.5 +45 fit, so do 18x8 +45.
Thanks
Old 11-23-08, 01:12 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
it doesnt depend on offset, it depends on disk.
you need High disk wheels.
Old 11-24-08, 12:58 AM
skperformance
skperformance's Avatar
agreed , x-factor or back spacing is the requirement.
Old 12-02-08, 01:31 PM
MEANDAFAKA
MEANDAFAKA's Avatar
stick that back boy out by getting something crazy.
Old 12-02-08, 02:32 PM
steveski
steveski's Avatar
True - I ordered many sets of wheels B4 learning of high disk High disk with 45 offset would be fine though.
Old 12-02-08, 06:10 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Yes the 2nd and 3rd gen LS has huge calipers sticking out even more then bigger (in diameter) aftermarket systems. Wish they would have given some of that braking power to the GS
Old 12-02-08, 11:45 PM
skperformance
Grand i think something is wrong with your GS is if has poor brakes , my stock 03 GS430 brakes amazing compared to my upgraded LS .
Old 12-03-08, 05:59 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
First, Congrats on the GS by the way.
The FIRST bite isn't bad, but if you're on the highway and brake 3-4times, its all fade from there. The problem is the immense amount of brake fade non-existent on my previous or currently LS. The LS has much more confident and predictable braking. I wish i can install some 3GS 4-piston calipers on the 2GS.
Old 12-03-08, 09:52 AM
PureDrifter
BahHumBug
you could install the 2LS 4piston alum. calipers, you just need a couple of RCAs for the front lower balljoints, not more than $250 or so. you get free 1/2" lowering and clearance to fit the brakes
Old 12-03-08, 05:08 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
AND wheels AND spacers for my winter wheels.
Spacers + RCA's somewhat scares me.
Old 12-03-08, 06:50 PM
PureDrifter
BahHumBug
ichiba 25mm adapters+Exact spacers+2LS calipers and you'd be set
Tom57
11-23-15 12:33 PM
junkyard03
Suspension and Brakes
09-22-14 11:51 PM
Durrr
07-23-06 03:32 PM
chuckb
Wheels, Tires & Brakes Forum
11-29-04 02:57 PM
pvo
02-13-04 06:11 PM
Quick Reply: 98 LS Brake Clearance Question
