Steering wheel remove?
Old 12-05-08, 01:55 PM
VIP_LS
VIP_LS's Avatar
Default Steering wheel remove?
Does anyone have instruction to remove the steering wheel in here?
Old 12-05-08, 02:31 PM
LiCelsior
Retired
LiCelsior's Avatar
did u try searching first? think i saw it somewhere recently..
Old 12-06-08, 02:02 PM
VIP_LS
VIP_LS's Avatar
yes I have I thought I saw it too but it was someone who asking the same question.
Old 12-06-08, 02:39 PM
sirCharles
sirCharles's Avatar
What kind of new steering wheel are u gettng?
Old 12-07-08, 05:36 PM
VIP_LS
VIP_LS's Avatar
[QUOTE=sirCharles;4062773]What kind of new steering wheel are u gettng?[/QUOTE
its came off from 01 gs300. I want to put it on the 93 sc300
Old 12-08-08, 07:02 AM
RandomHero
RandomHero's Avatar
Easy, make sure the steering wheel is fully out and fully down that way it won't auto adjust up and you're stuck working with limited space.
With that said, pop off the two side covers on the wheels (shouldn't be any bigger than 1"x2" and you'll see 2 hex bolts on each side of the wheel, totaling four.
Removed these, take off the airbag, disconnect it, then you're left with one big nut holding the wheel on. I believe it's a 19mm. Remove this nut and in order to remove the wheel, sometimes it is necessary to wiggle it back and forth instead of pulling it straight away. That should be it really.
Hope that helps!
Old 12-08-08, 11:50 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
you may wanna look in the SC forum then.....
Old 12-08-08, 12:19 PM
RandomHero
RandomHero's Avatar
lol.
Words of advice right there!
Old 12-08-08, 06:21 PM
VIP_LS
VIP_LS's Avatar
I just bought the sc and I'm sure that they're very similar to remove. Not sure where to start but worth the try.
Old 12-10-08, 06:02 AM
JRiftin
JRiftin's Avatar
i've done it.
Most importantly, Disconnect the battery first........
Old 12-10-08, 06:07 AM
LiCelsior
Retired
LiCelsior's Avatar
yea dont want the airbag blowing up <1ft from ur face...im pretty sure the SC guys have a diy since some of them have the nardi quick release hub.
khizr23
01-07-19 02:04 PM
01_IS_4U
10-31-10 08:09 PM
badx33
11-11-09 10:04 AM
kylesc400
SC- 1st Gen (1992-2000)
07-18-04 06:25 PM
mdt525
01-14-03 03:45 PM
Quick Reply: Steering wheel remove?
