afm/maf
afm/maf
whatever you decide to call it, what do i do to make them stop breaking? i dont want to spend a billion dollars on a lexus new part if its going to go out again. is there a better one that i can use off a different model?
i first got my car and it ran great then after a few months it started to run like ****. replaced the maf with a junk yard unit and it ran great then this maf went out too. seems to be common problem and i am just looking for an end all fix.
apparenty the oil on K&N filters can mess up the wire on the MAF. ive been running mine for 1yr + and no problems. also cleaning with a MAF cleaner can mess it up also. maybe the one u bought from the junkyard was dying also?
u can spray this on ur maf to get the k and n oily residue off
http://www.autobarn.net/maairflsecl1...te=google_base
i got some carb cleaner and chased the intake looking for poss vac leaks with nothing so i took the maf out of the housing being careful to not touch anything on the air tract side and hosed it off with "maf" cleaner. let it dry for about 30-45 min and reinstalled. reset the ecu too. first drive out it was great for about 200 feet then it cut out, worse than ever before, like the engine completely died. been doing that ever since so i just unplugged it. runs much better and more smooth but im probably only getting 5mpg. any good replacements or am i going to have to fight this thing my entire ownership?
i do have an injen intake setup and am currently looking for a stocker. intake was installed by prev owner. didnt even know it had it for a month or so after i got the car.
i love the car but i wish it would just work right and have that reliability that toyota is known for. just make the engine light go away damnit. its seared into my retinas
and i really think there should be an end all sticky at the top. i am always searching on how to fix my stumble and maf. there are tons of threads on the subject but no real clear fix
agreed.
I hate to say it, but you might have ruined that MAF also by trying to clean it. I also know you said you were hunting for one, but take that aftermarket air cleaner off and toss it. I have seen several people ruin their MAF by having too much oil on their K&N. Put a OEM intake on and a new MAF. Also, i don't have a FSM but i would do the electrical tests for the MAF circuit to make sure it is sending correct voltage.
look at the posts of numerous members who ruined their MAFs by using sprays made for Carbs and EVEN those specially made for MAF/AFM sensors. the Lexus MAF is extremely sensitive to contaminants, which is also why those who overoil/don't sufficiently dry their oil'ed air filters also tend to kill their MAF sensors.
what i posted is not a carb cleaner,as a matter of fact i am at work right now,i have the product in my hand as we speak...nowhere on this label does it say anything about not using it on LEXUS maf sensors,in fact it says it is safe for all maf sensors....
turn off vehicle,do not apply while energized,unplug sensor,remove sensor housing,apply 10-15 sprays onto hot wires or hot plate,do not contact hot wires with straw or any other object....now read that and tell me where the problem lies? with the product or the person doing the work? this would not even be on the shelf if it ruined the sensors, we sell this tuff to auto shops all day...sometimes i dont know why i bother trying to help out...
