My LS =P
Old 12-25-08, 07:10 AM
whodablarg
whodablarg's Avatar
Talking My LS =P
I see everybody post pics of their ls so heres one of mine =P please tell me what you think, the cars got some mechanical problems and im wondering weather or not i should keep it...
Old 12-25-08, 07:17 AM
python
python's Avatar
what would u like to do with it? keep it stock or mod it out? what mechanical problems are u having?
Old 12-25-08, 07:34 AM
RandomHero
RandomHero's Avatar
x2...I bet you could find a lot of the answers you're looking for on here.
Old 12-25-08, 07:35 AM
whodablarg
whodablarg's Avatar
the engine knocks, im guessing its the lifters, i pulled off the covers n found sludege so i had an engine flush done its still clicking, i tried engine stableizer n its still clicking, and when i put the tranny on drive the whole car jumps, but its a smooth ride, i wanna do more to the car but everyone says its a bad investment =[
Old 12-25-08, 07:53 AM
python
python's Avatar
jumping into gear sounds like a trany mount....how many miles are on it?
Old 12-25-08, 07:57 AM
trukn1
NELOC Mod
trukn1's Avatar
Knocks or clicking??? The 1UZ motors in these cars (especially the earlier gens like your and mine) were famous for developing a valve tap over time. Is more annoying than anything else. The fix for it is a valve adjustment, the mechanic will have to install shims to correct the problem. Only bad thing about this is, if you are not mechanically inclined, or know someone who can do this, the fix is at least $1K. As far as the tranny,, I would recommend a drain (not flush) and fill using Toyota tranny fluid. Lexus transmissions are VERY sensitive to foreign fliuds, so a drain and fill may help your problem. This is the fluid you need to use in the tranny. You can buy it from Lexus, but cheaper if you buy from Toyota dealer. Could also be a tranny mount, which wears out over time. These cars are very good, but can be a bit of a hassle, if you got one that has been a little neglected. The money you invest in it will continue to improve it; just depends on how much you like the car, and what you are comfortable with investing.
Old 12-25-08, 08:08 AM
whodablarg
whodablarg's Avatar
its got 180xxx on it, its more of a click then a knock, its very stable and repetative, the car is fine and can handle very high speeds, but i dont want to put money into it if both the engine and tranny are showing signs of age =P im ganna have the tranny drained soon and see if it still jumps, if not i will check the mounts,
Old 12-25-08, 09:15 AM
Bradster
Bradster's Avatar
I personally would get the full tranny flush from a reputable shop of course...Only use T4 Toyota fluid...I would also replace the engine mounts along with the tranny mount...15 years on the road has worn the rubber down..so much heat...plus Texas heat! Your car will purr like a kitten!
Old 12-25-08, 10:51 AM
MEANDAFAKA
MEANDAFAKA's Avatar
holy crap, i can fit my head in the front tire gap. time to lower it.
Old 12-25-08, 04:53 PM
TJW98LS
TJW98LS's Avatar
Very tiny head you have there, sir. lol
I think the only reason it looks so big is because it appears that the tire isn't as high as it should be.
Good to see you've got G35 wheels on it, looks good.
grady ins.
25
10-25-19 09:27 AM
OCLSLexus
08-05-11 08:51 AM
7schulz
19
04-16-10 09:50 AM
ewhite
11-03-09 08:51 PM
jahummer
14
10-11-02 11:33 AM
Quick Reply: My LS =P
