they can be found, but generally are at LEAST 20-30mm deep, which would give you too low an offset to run in the front since the LX470 is already 8.5 +30.
The LS460 as well has a different drilling. You can use the range of LS wheels from '95-'07. Some of the 3-GS wheels will work too if that car came with the big calipers.
Right.
I was more of less referring to what PD had mentioned earlier. My fault for not asking a good question lol.
So, would the offset of the LS460 wheels after adapters make it too aggressive to run as well?
